Qriocity Video on Demand
glloyd
I've been trying to watch  movies on Sonys Qriocity video streaming service but I can't watch more than ten seconds on HD or SD videos without it stopping to re buffer. I've tried this over several days and at different times of the day with the same results. My sinc speed is well high enough at 14 meg so I'm wondering if the problem is with PlusNet traffic management. Any thoughts please because I've wasted nearly £15 so far.
29 REPLIES 29
Oldjim
Resting Legend
Fixes: 63
Re: Qriocity Video on Demand
Have you tried running Wireshark to see what it is seen as
glloyd
It's running into a Sony Blue Ray player so can't run Wireshark.
Peter_Vaughan
You need to raise a ticket and ask if the Sonys Qriocity video streaming service is in gold or treated as normal traffic (i.e. throttled).
jelv
Fixes: 10
Quote from: glloyd
Not true, but it's not so easy. You need to get hold of a HUB, not a switch. You need a PC and the Blue Ray player plugged in to the hub and the hub uplinked to your router. A hub echos all traffic to all ports so you can now use wireshark on the PC to monitor the traffic from the Blue Ray player.
Where you get a hub from might be another matter. You need to be careful as a lot of posting on eBay called hubs are in fact switches. I think you will find hubs will generally only be 10BASE-T (not 100mbps) - slower than your internet connection but fine for the purposes of investigating your problem. Netgear EN104TP or 3COM OfficeConnect are examples of such a boxes.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
glloyd
It definately traffic shaping as it was fine after midnight but I aint going to stop up all night to watch films.
jelv
Fixes: 10
Just dug out the hub I have used in the past for a similar problem (Wireshark couldn't see all the VPN traffic), it's a Linksys 5-port Workgroup Hub.
adamwalker
Fixes: 223
glloyd,
I've just checked your account and can see that you've been asked to run Qriocity on your PC, apologies I know this isn't possible. I've passed the ticket back internally to the right team. We'll check our traffic management system and let you know how this is currently prioritised and if we can see a need to change the priority.
 Adam Walker
glloyd
Thanks Adam, what would we do without you. Now you understand why customers get frustrated.
adamwalker
Fixes: 223
I certainly can when things like this happen. I've given the agents who dealt with the ticket some feedback on how it could have been handled better.
 Adam Walker
glloyd
Seems to be going back and forth again withone agent wanting me to download a film beween 8.30am and 5.30pm, no problem I can do that. But that was followed by another reply saying it's been passed to the correct department for a reply. Crazy Roll_eyes
orbrey
Hi glloyd,
Sorry about the delay on this, I'll make sure I chase it for you first thing tomorrow when everyone's back in the office.
glloyd
What a bloody shambles C/S is these days. I asked a simple question which has resulted in no end of replies some from agents asking the same question as I asked. If they can't sort out a minor problem like this god help those with more serious problems.
godsell4
If the BR player is wireless, then you stand some hope of using a wireless laptop running Wireshark to capture the data from the BR player too. I used this method some years back to debug some traffic shaping issue with a PS2 game which had problems due to the PN traffic management,
3Mb FTTC
orbrey
If you use a Thomson router you can mirror network traffic from one port to another, basically meaning that if the Blu-ray player is on port 3 then you can wireshark the traffic using a PC on port 4. Log in to the CLI (via telnet) on the Thomson and run the following:
:eth switch mirror capture port 3
:eth switch mirror ingress port 4 state enabled
:eth switch mirror egress port 4 state enabled
To disable it again afterwards just run the same commands with "state=disabled" after each:
:eth switch mirror capture port 3 state disabled
:eth switch mirror ingress port 4 state disabled
:eth switch mirror egress port 4 state disabled
Though I believe you may have been offered an alternative option on the ticket, please let us know which you'd prefer.
