Product change
Bendo
Product change
I want to add Anytime calls to my package, but going through the product change options shows my current package at it's current price rather than the discount I have on it for the lenght of the contract. The final step confirming the DD suggests that if I click submit I will lose the current discount, is this the case and I need to call someone to add anytime calls rather than do it online or should I just ignore the numbers the online system quotes and submit it anyway?
4 REPLIES 4
adamwalker
Fixes: 223
Re: Product change
Hi Bendo,
The account summary doesn't take discounts into account so it shouldn't be an issue. Changing accounts does remove discounts but we do add these back on unless another deal has been agreed on.
I've just scheduled the change of account type myself for you to be on the safe side.
 Adam Walker
Bendo
Re: Product change
Thanks Adam,
That should stop the missus running up a bill :).,
adamwalker
Fixes: 223
Re: Product change
Just to be clear in that case I want to make sure you're aware it's a scheduled change on your next billing date (11th)
 Adam Walker
Fixes: 251
Re: Product change
Quote from: Bendo
Do remind her that inclusive calls are only free up to 60 minutes duration... Too much uninterrupted chatting could still be expensive!
