Pointless use of flash on support webpages
ejs
Aspiring Hero
Fixes: 25
I have no idea why someone would decide to use flash to display what should presumably be a simple piece of text. It doesn't really work very well if you have the flash plugin configured as click to activate.
Edit: For example URL: http://www.plus.net/support/broadband/speed_guide/index.shtml?supporta=speedguide
17 REPLIES 17
pjmarsh
Fixes: 24
Re: Pointless use of flash on support webpages
Do you mean the bits in the screen headings?  They aren't showing as flash for me.  Looking at the source there isn't anything particularly special about them:
<h3 class="fullBoxHeader txtHeader"><span>Getting Started</span></h3>
Phil
jelv
Fixes: 10
You didn't look deep enough!
<object id="sIFR_replacement_1" class="sIFR-flash" width="127" height="25" type="application/x-shockwave-flash" name="sIFR_replacement_1" data="/assets/vagrounded.swf"></object>
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
pjmarsh
Fixes: 24
Ah right.  That isn't on that page for me.  I think we may have seen differences in support pages between business and residential before.  Something to do with the stylesheets when printing maybe?
Phil
jelv
Fixes: 10
Did you delve down fully in to the class?
pjmarsh
Fixes: 24
Yep, no sign of it for me.
LinnPlusnet
I'll flag this up to the Web Team, ejs.
Sorry for any inconvenience caused by it.
Fixes: 246
Also consider that Flash does not work on iApple devices due to technology licensing arguments!  Roll_eyes
TORPC
Well spotted / remembered / researched Townman Wink
Fixes: 1,495
Also on this page
http://www.plus.net/support/service/network_performance/network-latency.shtml
flash block to the rescue again Roll_eyes
also adobe stopped official support for it in jellybean..
TORPC
With plugin allowed
With Plugin Blocked
ejs
Aspiring Hero
Fixes: 25
The page will display fine if you don't have flash installed. It's only a problem if you have flash installed but set for click to activate. Still seems fairly pointless to use flash just to display a piece of text.
TORPC
a simple [code=HTML]<p>TAG</p> [/code]would suffice Wink
Fixes: 246
Quote from: TORPC
Working knowledge - one reason I've never used flash in web site developments - iApple is becoming very predominant / the browser of choice, so there is little point developing websites using unsupported technologies... especially to display what is otherwise plain text which would be better rendered via CSS / CSS3.
TORPC
Applies to all 3 then Wink Grin
