Plusnet just gets better and better ! ! !
shutter
Fixes: 67
This time last year, I was struggling to get 1.2 meg speed on my wireless internet connection, more often than not, I was getting just under 1 meg…
However… I never expected to see these kind of speeds from a BT speedtest on my line, which is about 3 km from the exchange.
With the router at the end of a 15 metre hardwired extension from the “master socket”…
Date…………speed achieved……… max achievable speed… DSL Rate ..…..IP profile
15 March ………..3893…………………...4000……………...4600………….....4000
15 March (20:36) ..3838………………...…4000……………...4600…………….4000
31 March  (10:45)...4199…………………...4000……………...4600…………….4000
4 REPLIES 4
Alxns
Re: Plusnet just gets better and better ! ! !
Maybe theres less wireless interference ?
hamilton36
Well, Shutter!
You are lucky indeed. I could not log on at all from 19.00hrs last night and I gave up at 02.00hrs this morning!  It it was not my router, because I have 2 and both were connected to the default network but the Internet light was out.
Alex
shutter
Fixes: 67
Quote from: KyleS
My laptop is "usually" only a couple of feet away from the router... however the first two speed tests were done about 25 feet away, in another room, with a brick wall between me and the router...
Wireless interference has not been an issue in my location.... (I use Routerstats and inSSIDer to check )
Thinks. !  must do a "wired" connection test some time... to see how fast the line really is  Cheesy
pierre_pierre
Quote from: hamilton36
Well, Shutter!
Alex
could be this http://usertools.plus.net/status/archive/1301539220.htm
http://usertools.plus.net/status/archive/1301556020.htm
