Plusnet - New Network
Re: Plusnet - New Network
That article was generated as a direct result of one of the post here, so if Darkfire hadn't of made the comment he did then we'd still be none the wiser.
AndyH
Quote from: rongtw
I fail to see why PN has deiced to keep this a secret  Crazy
http://www.ispreview.co.uk/index.php/2016/01/uk-isp-plusnet-quietly-swaps-to-a-dedicated-wbmc-networ...
I assume there will be some kind of announcement when they begin migrating large numbers of users. But I doubt there will be any explanation of the technical details of the new network. Nothing changes and for me, the only noticeable difference was slightly better latency.
Quote from: andrewsimk
Been moved onto the new network myself, but now I can't authenticate with the system, tried multiple routers, modems,cables and had engineer.
Have you tried the BT test accounts?
Anotherone
Champion
Fixes: 21
kitz has already suggested that to the poster on his own thread!
summers
Quote from: spoon
Could someone who's had one of these messages post the output from
tracert ntp.plus.net
please.
My connection (from Bath so probably via Bristol) goes: CentralXX.ptn-bngXX -> ptw-crXX -> ptw-gwXX
So question is how do you translate those names into a route, unless you have some knowledge of the network topology? I can't find a map of the pusnet topology, so don't know which machines are in the central routing facility - unless the Central but aboe is a give away? E.g. can you test being on the new network by not seeing Central?
Thanks,
David.
jelv
Fixes: 10
ptn is telehouse north in London so your tracert isn't telling you anything about your routing.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
HarryB
Fixes: 256
Quote from: summers
Quote from: spoon
please.
Thanks,
David.
Just FYI, you're not on the new network.
 Harry Beesley
jelv
Fixes: 10
Harry, will anyone who is on the new network see pcl/ptn/ptw as their first hop after the router? It was earlier suggested that some people would not see a routing change (i.e. their connection would still be tunnelled to the London gateways).
chrcoluk
Expect a lower latency as the first external hop, probably on a ip with no rdns.
jelv
Fixes: 10
What percentage of users will be moved across when this project is completed?
rongtw
Fixes: 12
i would presume that all PN customers would be moved .
But the lack of input from PN is deafening  Lips_are_sealed
HarryB
Fixes: 256
Quote from: jafreer
Quote from: Bob
it won't be obvious to everybody when they've been moved i.e. you won't all see traceroutes like that ^
Will everyone be getting moved over Bob?
Quote from: Bob
Yeah, I believe that's the intention. There's a *lot* of circuits to move though so it will take some time.
 Harry Beesley
jafreer
Not sure if this has already been answered, but does the second hop shown below to 206.core.plus.net mean I am on the new network?
Thanks.
Tracing route to ntp.plus.net [212.159.6.10]
over a maximum of 30 hops:
  1    78 ms  101 ms  101 ms  BThomehub.home [192.168.1.254]
  2    26 ms    24 ms    24 ms  206.core.plus.net [195.166.130.206]
  3    25 ms    25 ms    26 ms  irb.13.ptw-cr02.plus.net [84.93.249.50]
  4    25 ms    25 ms    26 ms  po2.ptw-gw02.plus.net [195.166.129.39]
  5    *        *        *    Request timed out.
  6  141 ms  101 ms    24 ms  FWDR-10.FWDR-6.FWDR-159.FWDR-212 [212.159.6.10]
Trace complete.
AlaricAdair
Champion
If the announcement was symmetric FTTP with IPV6 to all customers, I might be impressed. BT has had long enough.
Now Zen, but a +Net residue.
bobpullen
Fixes: 331
Quote from: jafreer
That's ptw-bng02 I think, it's just the rDNS is wrong.
jafreer
The gateway checker shows me connected to pcl-ag02 so not sure why the 206.core.plus.net is there.
Bob - is there a way to tell when one is moved onto the new network?
