Plusnet - New Network
Luzern
Fixes: 9
Re: Plusnet - New Network
Well from long human female experience, the change is about 45 years after roll-out! Tongue
avatastic
Quote from: avatastic
Assuming my PPP drop at 3am this morning was me being moved to the new network, I can confirm that my static IP block has remained with me, my firewall hasn't been reset, I've not been dumped on 40/2 from 40/10.
I do seem have been dumped on an ADSL2 profile of 21Mbps though.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Anotherone
Champion
Fixes: 21
Somebody's made a slip-up, I take you've been on Chat or Phone and it's now been updated?
avatastic
Hijacked another 40Mb sync /21Mb profile forum thread and it got fixed.
Could be something up with the migration process that incorrectly resets the profile, which is why I highlighted it here also.
St3
Aspiring Champion
Fixes: 5
still no sign of a move yet  Crazy
bobpullen
Fixes: 330
I understand it's more of a data integrity issue. In isolated cases there are people on fibre whose accounts are flagged in the system as being on the incorrect provisioned profile i.e. ADSL. When orders complete it resets the line profile to the maximum achievable on ADSL. We've been looking into this, however it should only have an impact on those with static IPs at present.
jelv
Fixes: 10
Does traffic prioritisation still apply on the new network for people without static IPs?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Luzern
Fixes: 9
Next bit of useless stuff! Grin
I think I must have just gone over, but you may prove me wrong from the tracert! Comment?
Microsoft Windows [Version 10.0.10586]
(c) 2015 Microsoft Corporation. All rights reserved.
C:\Users\Gordon>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.244.22]
over a maximum of 30 hops:
  1    1 ms    <1 ms    <1 ms  192.168.1.254
  2    30 ms    29 ms    30 ms  lo0.11.Central11.pcl-bng04.plus.net [195.166.130.178]
  3    31 ms    30 ms    30 ms  irb.11.PCL-CR02.plus.net [84.93.249.98]
  4    31 ms    31 ms    31 ms  ae1.ptw-cr02.plus.net [195.166.129.2]
  5    65 ms    30 ms    30 ms  ae2.ptw-cr01.plus.net [195.166.129.4]
  6    32 ms    30 ms    30 ms  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
  7    *        *        *    Request timed out.
  8    *        *        *    Request timed out.
  9    31 ms    30 ms    31 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
10    37 ms    37 ms    36 ms  132.185.255.148
11    31 ms    31 ms    31 ms  212.58.244.22
Trace complete.
Also got a small increase in sync.
paulmh5
Quote from: jelv
Yep, traffic marking is still there as is prioritisation although it's implemented in a slightly different way.
Plusnet Staff - Lead Network Design/Delivery Engineer
HarryB
Fixes: 256
Quote from: lucerne
Doesn't look like you've moved yet (Judging from the account connected to your forum account ;))
 Harry Beesley
Luzern
Fixes: 9
Ah well, no matter! It was that the trace had much more Plusnet than I'd see before. Embarrassed Roll_eyes
Referring to this topic - "anyon got moved to the new plusnet ( so called 21st century IP address platform?"
The poster is suggesting that it is now more difficult to change their dynamic IP address on the "new network", than previously.
Is there any any reason why that might be the case ?
Huh
paulmh5
Quote from: Nibiru
Yes.  IPs are allocated to your local BT BRAS in small chunks and as BT map you to a single BRAS then you only have that selection to 'pick' from.
jelv
Fixes: 10
As more users are moved across will the range of IPs allocated to each BRAS increase?
paulmh5
Quote from: jelv
Yes, the system which manages the IP pools will allocate another block once the current ones reach 90-something percent.
