Plus.net - negative.service
- Feedback
- Plusnet Feedback
- Re: Plus.net - negative.service
11-01-2012 5:48 PM
There will be a remainder i am not doubting that at all nor do i have an issues over that amount. i do have an issue over the £35 or mobile calls which you have agreed to sort.
Upload still spikes at 1mbps then drops to 0.3mbps constant.
12-01-2012 10:12 AM
ARGHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Another 2 hours on the phone today then ?
12-01-2012 10:26 AM
12-01-2012 10:34 AM
Just spoke to someone and again was misinformed it is fixed and should be OK to use right away... And it isn't... do you have a higher than high escalation?
This is really taking the biscuit.
Also Tracey is in the billing team is absolutely spot on. Loving soothing voice.
12-01-2012 10:40 AM
Quote do you have a higher than high escalation?
It depends what you want to achieve, I can deal with any issues you may have, however as far as I'm aware everything is in hand right now and we're just waiting for the call barring to be removed.
Quote Just spoke to someone and again was misinformed it is fixed and should be OK to use right away
That's not what I gathered from speaking to the agent I spoke to so I'm sorry if that was the case.
12-01-2012 10:40 AM
Quote Dear Mr Smith,
As per our conversation today a call bar was again added to your phone, my college has removed this so your home phone should be again ready to use. If I can be of any further assistance please do not hesitate to call.
Kind regards,
And its not ... suprise sur-fricking-prise
This ticket clearly shows he implies it is immediately available
12-01-2012 10:49 AM
Adam can youcall me on the mobile number on the account ending in 932?
12-01-2012 11:41 AM
12-01-2012 11:44 AM
12-01-2012 11:46 AM
You have to ring in or write a letter.
12-01-2012 11:47 AM
12-01-2012 11:49 AM
12-01-2012 11:51 AM
Also i have done nothing but speak to customer options in the last 2 days its a joke. I need this phone line for important calls and twice through no fault of my own this has been messed up. The first time fair enough mistakes can happen but twice in 24 hours then people denying things are being said despite them being written in a support thread is a bit unjust.
14-01-2012 2:22 PM
15-01-2012 11:44 PM
I understand all the problems & frustrations you're having. Keep going with whatever complaint direction you're going.
However, I did want to comment on one tiny little aspect (and it took me a while to decide whether it was worth commenting)...
Quote from: andre88uk I need this phone line for important calls and twice through no fault of my own this has been messed up.
On the second occasion, you did put yourself at risk of being messed up, by cancelling the Direct Debit. I know you had a valid reason, and didn't want that action to disable the line (indeed demanded that it didn't happen), and that Plusnet didn't want that outcome either. But by choice you made sure that a payment was going to be missed, and it all then came down to whether the technology behind the scenes could be made to ignore the missed payment.
You absolutely have the right to cancel the DD, and to complain to Plusnet. But in a risk assessment, you surely had to weigh up the importance of the calls that might be missed against the possibilty that cancelling the DD would cause exactly that to happen.
Please don't misunderstand me - this isn't about whether Plusnet were right or wrong. It is only about the risk of things going wrong, or making things worse, and whether you could live with that risk.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
