PN is a rip off
monkey001
Re: PN is a rip off
Date Download Speed Upload Speed
Today 22:29 412 kbps (51.5kB/s) 383 kbps (47.9kB/s) Share
Today 22:25 359 kbps (44.9kB/s) 378 kbps (47.3kB/s) Share
Today 20:01 512 kbps (64kB/s) 374 kbps (46.8kB/s) Share
Today 19:47 138 kbps (17.3kB/s) 364 kbps (45.5kB/s) Share
few more i got after starting
scootie
Re: PN is a rip off
can you install this and monitor your error counts http://www.vwlowen.co.uk/internet/files.htm
you will find the error counts on the telnet tab and under summary
James
Re: PN is a rip off
It's also worth monitoring your connection to see if it is actually dropping aswell.
If so, that's likely to be the reason for the fluctuating pings.
monkey001
Re: PN is a rip off
Quote from: ASBO
i cant seem to find the error count on the telnet tab here what i can see only just started it though
and thanks for the help
monkey001
Re: PN is a rip off
this is bad takes ages to load up pages basically i cant use the net or game atm
scootie
Re: PN is a rip off
this telnet tab. the one your on is the setup options
which version of netgear do you have?
if you click enable telnet and your version of netgear on the telnet setup from your capture above the telent summary tab should now be working
also is it the offical firmare or the DGteam firmware
pierre_pierre
Re: PN is a rip off
I am not using my PN line at the moment, but the speed have been rubbish tonight "football"?, just got 150% better
monkey001
Re: PN is a rip off
Quote from: ASBO
netgear dgn2000
em nothing showing atm ill have a play with it
unsure what you mean on the fireware
there my router is atm i always get high error seconds 700 to 900 if i remember right from thr PN report so i did put it on the test socket got less error seconds down to nothing im sure but lossed well over 0.5 mb on the speed and sinc so i put it back where i had the better speed.
the ping was still rubbish on the test socket no chance whats so ever
Today 17:22 155 kbps (19.4kB/s) 368 kbps (46kB/s) Share
Today 16:56 142 kbps (17.8kB/s) 379 kbps (47.4kB/s)
no sign of improvement whats so ever infact its got worse
is this speed what you expected to see ? i did expect a drop but not this much
can i put the interleaving back on myself as i will be mostly working from home next week and need better speed then this or will i have to ask a PN staff member
monkey001
Re: PN is a rip off
can someone turn interleaving back on or how it was before this is 10x as bad gonna end up smashing something or start crying
scootie
Re: PN is a rip off
have to raise a ticket and request interleaving turned back on.
at this time of night i doubt it would be picked up in time for when BTw do batch of orders at 2am so most likely a 24hour wait for you.
can allways post the ticket number here and maybe if there is a passing PN staff member they might push it through in time for you
monkey001
Re: PN is a rip off
ID: 30042995 ticket no for interleaving to be turned back on
thanks VERY much abso dog you have been a help
just wish this worked
scootie
Re: PN is a rip off
following from here http://www.vwlowen.co.uk/internet/files.htm
With the Netgear DG834, DG834G, DG834GT, DG834N, DG834PN and DGN2000 series of routers, RouterStats is also able to automatically establish a Telnet connection for access to additional statistical data. From version 4.3 I've added support for the 'unofficial' DGTeam firmware (hopefully).
you should be able to telnet into the dgn2000 using routerstats pretty easy to get the extra info
James
Re: PN is a rip off
Hi - I've placed an order to turn interleaving back on and this should complete on Monday.
monkey001
Re: PN is a rip off
Quote from: ASBO
leave it with me ill try and get something sorted tonite as im now stuck with this till monday thanks PN
monkey001
Re: PN is a rip off
is that what you was after?
