PHP Multibyte String Functions library
- Feedback
- Plusnet Feedback
- PHP Multibyte String Functions library
31-12-2008 3:10 PM
Hi - I'm developing a website on the Plusnet CGI server using PHP and the mySQL support.
A PHP utility that I want to use needs the "PHP Multibyte String Functions library" to be installed on the server.
Not a library that is installed by default, but....
...any possibility of this being made available (very) soon?
thanks
ps not sure if this the best vehicle for this request but will also ask same question under Support on my Plusnet account
thanks
2 REPLIES 2
Re: PHP Multibyte String Functions library
31-12-2008 3:16 PM
Quote from: yydelilah Hi - I'm developing a website on the Plusnet CGI server
Is this a good idea as the CGI box is going to be turned off in a few months time - I suggest you look at PAYH (this may have what you are looking for anyway).
http://community.plus.net/forum/index.php/topic,69283.0.html
01-01-2009 10:06 AM
Thanks for the info - didn't get wind of the changes!
