Not happy and leaving :(
cartman
Poor service, suffering from disconnections (135k profile) fed up with poor connection and leaving to LLU, did ring support today and wasnt happy with the responce " is there any road works in your area?" had 4 enginneers etc etc.
65 REPLIES 65
Epyon
Re: Not happy and leaving :(
Good luck
who you going with?
pierre_pierre
from 26/3
if this has put me back to another 3 days wait then i am off from monday to TT LLU..
:D :D 8) :crazy:
Steve
Seasoned Pro
Oh the grass Is greener ( You think )? ::)
UPDATE2 ISP TalkTalk UK Suffers Serious Web and Voice Service Failure
Internet and phone provider TalkTalk ( AOL UK , Tiscali , Opal ) has today been struck by a serious network failure that resulted in a number of key websites and services being taken offline.
Sauce...http://www.ispreview.co.uk/story/2011/05/06/isp-talktalk-uk-suffers-serious-web-and-voice-service-failure.html
If life gives you lemons, make lemonade.
tony8436
So TT having problems means it ok for PN to be bad?
Steve
Seasoned Pro
Message contains a hyperlink
Did I say that? lQQK at your poll, That paints a very special picture.
http://community.plus.net/forum/index.php/topic,95559.0.html
tony8436
Lets not move the issue I have had to other peoples thread.  I have not mentioned it here as it is not relevant, so if you have something to say about it, PM me or post in my thread.
spraxyt
Resting Legend
Quite clearly the point is that from the sample of 50 users voting in that poll 95% don't think Plusnet are bad. Wasn't that the premise you raised in the current thread?
David
tony8436
Another one who can't read.  Anything to do with my thread, say it in my thread not other peoples.  It really is quite simple.
cartman
8) TT LLU anything is better than this, our neighbours both sides have had no problems with TT and average speeds is over 10mbps.
Just want to use youtube+iplayer but cant on 135k and LLU means i wont be waiting 72hours to recover which I know isnt PN fault?!!!
:crazy:  :-X
DSL Connection
Link Information
Uptime:
0 days, 0:15:43
DSL Type:
G.992.1 annex A
Channel mode:
Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]:
1,148 / 7,360
448 / 7,296
Data Transferred (Sent/Received) [kB/kB]:
0.00 / 183.00
Output Power (Up/Down) [dBm]:
12.0 / 19.5
Line Attenuation (Up/Down) [dB]:
10.0 / 19.0
SN Margin (Up/Down) [dB]:
26.0 / 15.5
tony8436
Also TT extra is only £3.49 + line rental.  Cheaper and faster than PN.  Go for it.  You will get a better service, faster response times to faults, a faster speed and more reliable ISP for a fraction of the price.
Steve
Seasoned Pro
Quote from: tony8436
Not true trust me op, Been there done that wore the T-Shirt, If there Is a fault on your line you will only take It with you, I notice your uptime on your router Is only 15min? Why Is that? Did you disconnect or did It disconnect Itself?
David_W
I'd say avoid TalkTalk and go for a TalkTalk reseller, they use the TT LLU gear but you don't have to suffer with TT. Xilo
tony8436
TT have to be better than PN. Nobody could be worse.  The only reason people stick up for them here is that they have probably never been with another ISP and believe everything that they read or PN tell them.  Fair enough, the fault may move with you, but it will be sorted alot quicker if you take it to someone else.
Steve
Seasoned Pro
Its a well known FACT that talk talk Is worse, Please stop trolling this fellows thread unless your really are able to help him. I have been with TT as have many others on this forum and I can promise you they will all tell you the same thing.
