No phone line
- Feedback
- Plusnet Feedback
- Re: No phone line
No phone line
30-04-2015 3:23 PM
estimated repair complete date is friday 8th may.
the service when working from plusnet is fine when something like this goes wrong, they are just unable or unwilling to help. redirect phone calls would be an obvious service at no charge. some hope. at the end of this there will be a long letter requiring a refund of line rental, compensation and damages. i will follow the post and result of "rangertim" posting 13/07/2011 and subsequent posts luckyman
adie:red removed all caps post as per link:rules]
1 REPLY 1
Re: No phone line
30-04-2015 5:20 PM
Hi LUCKYMAN,
I'm sorry to hear that this fault has affected you. You have summed up the situation in terms of the fault pretty well, and I can only really provide a small advance on that.
It looks like a joint needs to be remade somewhere along the line. I can see that council permission will be required to dig into, and fix the joint. I have to be honest and say that whilst they have given us a review date of the 8th, faults can often persist a bit longer when council permission is needed. This is because Openreach have to submit excavation drawings and forms, and it needs to be granted by multiple parties.
We'll check back on this date (or shortly after), and will provide you with an update. Of course, all downtime will be refunded back to you.
Matty
Matty
