New to Plusnet
abrad52
New to Plusnet
Hello everyone, I am new to plusnet this week. I am on the value package at presaent, could someone tell me if I get any e-mail account with this package.
Andy
9 REPLIES 9
pierre_pierre
Re: New to Plusnet
Welcome to the forum
Not sure what you are after.
PN send you an e-mail to "Postmaster" at the end of your billing month with the amount they are going to take from your bank
All other transaction are via the internet on the Members section, they dont use snail mail at all
tonycollinet
Re: New to Plusnet
Yes you do.
If you log on to the member center (www.plus.net) click on "Memeber Center" and use your logon ID and password - then you can go to Connection Settings (Under My Account on the LHS), then click "Connection Details", and you should see your email details near the bottom of that page.
itsme
Re: New to Plusnet
Strat
Fixes: 565
Re: New to Plusnet
You can also view mail at https://webmail.plus.net/src/login.php
jelv
Fixes: 10
Re: New to Plusnet
Quote from: itsme
You need to go https://portal.plus.net/my.html?yfEhVqhSKgPJx2%2BAdZQ7qhGvNgoXUgKqC3f0fFmIgOsmrrsujjYNOoAbUr2%2FgAxC... to setup and control you email account.
That link is specific to your session and will not work for another user. The link you need to use is:
http://email.plus.net/
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Ellis
Re: New to Plusnet
Yes, you get email facilities with your value account and you also get a small webspace if you want to set up a simple website.
I always advise my colleagues to use either their own domain (which I do) or something else which is independent of your ISP. If you change ISP's then you don't have to change your email address. A colleague recently changed to Plus Net and I was trying to obtain a permanent address for him on our club website when he phoned to say that his college had offered all retired employees a permanent "for life" email address. So that solved the problem.
jelv
Fixes: 10
Re: New to Plusnet
Quote from: Ellis
New users don't get webspace!
abrad52
Re: New to Plusnet
Hi all,  thank you very much for your replys, I will have a look at all the links and see what I can find.
Ellis - I already have a domain name, hosted else where - if anyone is interested its www.absbta2011.co.uk and I have some e-mail address which finish in @absbta2011.co.uk.
Thanks again
Andy
Re: New to Plusnet
One thing that hasn't been mentioned is that once you have set your new email address up in the member centre (it will read as [email protected],) you will need to send an email to it in order to activate the mailbox.
