New package...and 80% slower speed. WOW
firedemon1
Yesterday I was switched over to Plusnet Premium.  I wanted to go on that because I can't leave my PC on over night so thought the 80Gb allowance during peak times would be great.
And what happened?  My already puny 2.5Mb link (which rarely got above a 300kbs effective download speed) dropped its effective speed to a breathtaking 50kbs between 4pm and, roughly, 11pm.  This is utterly absurd.  Tried phoning AND raising a ticket but to no avail.
Frankly, I'm sick of complaining about it.  Load of rubbish
20 REPLIES 20
bobpullen
Fixes: 330
Re: New package...and 80% slower speed. WOW
Had a quick look at your account and I can't see any reason for this at all Huh
Your IP profile is currently 2000kbps so you should be able to achieve a maximum throughput speed similar to this. You're not mixing up your kilobits and kilobytes are you?
2000kbps or 2Mbps =  250kBps.
What does a BT speedtest tell you?
firedemon1
LOL
So now I'm paranoid that I've got my numbers wrong (and I work in ICT support)
I will take a deeeeep breath and re-check / re-test everything tonight
Watch this space
Chris
Legend
Fixes: 169
Re:New package...and 80% slower speed. WOW
Let us know how the retesting goes, we'll keep an eye out for the results.
firedemon1
Copied From BT test:
Download speed achieved during the test was - 1664 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
BUT
When I try to download a large test file from thinkbroadband.com the download speed fluctuates between 50KB/Sec and 85KB/Sec
So, my practical, real time download speed is significantly lower than the tests are suggesting
pierre_pierre
premium is not line speed for downloading see http://www.kitz.co.uk/isp/plusnet_shaping.htm
firedemon1
NOW I get it
Ok, so 4pm to 10pm I'm not going to get anything special (not that my connection is all that special in any case)
Thanks pierre_pierre
And thanks to Bob and Chris as well.  I guess I'm never going to see blistering speeds until BT do something to improve my line.
firedemon1
Out of interest, is my exchange ADSL2+ enabled?  Could that be my way forward to broadband nirvana?  Cheesy
Strat
Fixes: 565
Pop some info in here firedemon1 as a start.
Your looking for the 21CN WBC status.
pierre_pierre
but take a bucket of something with you, it says my date was 29/9/09, but dont think it has been done yet, there is another list, offto try and find it
pierre_pierre
Strat
Fixes: 565
...but it helps to have the exchange code from my link to use Pierre's link. Wink Smiley
pierre_pierre
Sam knows
ADSL status: Enabled as of 29/06/2001
ADSL Max status: Enabled as of 30/03/2006
SDSL status: Not available
21CN WBC status: RFS date set : 29/09/2009
21CN PSTN switchover target: Q2 2009
BT list    -      EABNT LONDON NORTH WEST 01/02/2010 28/02/2010
pierre_pierre
and its a long list, I had to do a control F (search) for the exchange code, not the exchange name
Strat
Fixes: 565
21CN WBC status: Not available Cry
