New package...and 80% slower speed. WOW
- Feedback
- Plusnet Feedback
- Re: New package...and 80% slower speed. WOW
19-11-2009 7:55 PM
And what happened? My already puny 2.5Mb link (which rarely got above a 300kbs effective download speed) dropped its effective speed to a breathtaking 50kbs between 4pm and, roughly, 11pm. This is utterly absurd. Tried phoning AND raising a ticket but to no avail.
Frankly, I'm sick of complaining about it. Load of rubbish
19-11-2009 8:56 PM
Your IP profile is currently 2000kbps so you should be able to achieve a maximum throughput speed similar to this. You're not mixing up your kilobits and kilobytes are you?
2000kbps or 2Mbps = 250kBps.
What does a BT speedtest tell you?
20-11-2009 8:49 AM
So now I'm paranoid that I've got my numbers wrong (and I work in ICT support)
I will take a deeeeep breath and re-check / re-test everything tonight
Watch this space
Re:New package...and 80% slower speed. WOW
20-11-2009 11:48 AM
20-11-2009 5:38 PM
Download speed achieved during the test was - 1664 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
BUT
When I try to download a large test file from thinkbroadband.com the download speed fluctuates between 50KB/Sec and 85KB/Sec
So, my practical, real time download speed is significantly lower than the tests are suggesting
20-11-2009 7:20 PM
20-11-2009 7:47 PM
Ok, so 4pm to 10pm I'm not going to get anything special (not that my connection is all that special in any case)
Thanks pierre_pierre
And thanks to Bob and Chris as well. I guess I'm never going to see blistering speeds until BT do something to improve my line.
20-11-2009 7:55 PM
20-11-2009 8:02 PM
Your looking for the 21CN WBC status.
20-11-2009 8:18 PM
20-11-2009 8:24 PM
20-11-2009 8:27 PM
20-11-2009 8:30 PM
ADSL status: Enabled as of 29/06/2001
ADSL Max status: Enabled as of 30/03/2006
SDSL status: Not available
21CN WBC status: RFS date set : 29/09/2009
21CN PSTN switchover target: Q2 2009
BT list - EABNT LONDON NORTH WEST 01/02/2010 28/02/2010
20-11-2009 8:32 PM
20-11-2009 8:34 PM
- Feedback
- Plusnet Feedback
