My new service does not work
- Feedback
- Plusnet Feedback
- Re: My new service does not work
09-03-2013 8:58 PM
New customer - conflicting msgs - either fri or sat switch on but it still does not work reported yesterday at a little after 6pm and now Sat almost 9pm and no update
help or contact.
That would help Scott -
and Moderator - I only started one after the first and did not know a thred / post could be modified.
OK
Hi Scott - many thanks for the update and helpful to get a text and email as well -
Thanks again -
THANK YOU SCOTT - VERY NICE GUY ARRIVED FROM OPENREACH AND GO US UP AND WORKING - GREAT PERFECT - AND ALL WITHOUT THE HASSLE OF AS WITH VIRGIN TRYING TO PHONE SOME OFF SHORE CALL CENTRE
THANKS AGAIN
help or contact.
OK
Thanks again -
THANKS AGAIN
5 REPLIES 5
Still waiting
09-03-2013 9:58 PM
Your Response
6:42pm, Friday 8 Mar 2013
We are currently performing tests on your broadband service which will allow us to investigate the problem you've reported.
Please be aware if this is a new fault that this can take up to 24 hours.
We'll contact you as soon as we have more information and let you know what happens next.
>>>>>> STILL WAITING<<<<<<<<<<<<<<<<<<<<
09-03-2013 10:06 PM
Post merged
Please don't keep starting new threads
09-03-2013 10:13 PM
Hi andyindundee,
From what you have posted it looks like you have raised a fault with us, it would normally be 48-72 hours before we would be in touch to let you know what is happening.
The message you have posted relates to how long the testing period can be.
I will have a look over your account in the morning though to see what is happening for you and see if there is anything I can do tomorrow.
If there is a fault we won't be able to progress this until Monday for you at the earliest when the faults team are back in.
10-03-2013 8:36 AM
I've just checked over your account and run some checks and it has found a fault on the phone line.
I have raised this for you and have updated your ticket with the estimated repair time.
Hope that helps.
Hope that helps.
11-03-2013 1:24 PM
