Migration Query
- Feedback
- Plusnet Feedback
- Migration Query
Re: Migration Query
12-05-2010 1:26 PM
Quote from: adamwalker Good morning dogwhisperer,
Also we understand that your speeds may not compare to an LLU provider that you may have used in the past. However we do not offer a service in comparison with LLU so there are no guarantees that speeds provided by a supplier such as us that uses BT wholesale's equipment would match those of an LLU provider.
Adam
Adam,
I have already mentioned that my previous supplier was NON LLU......ie using BT equipment such as yourself, so your argument just doesn't hold up.......
Rather than arguing with me or trying to pick holes in anything I say it would be better if you just fix the problem as promised.....
Re: Migration Query
12-05-2010 1:31 PM
http://www.ispa.org.uk/
Re: Migration Query
12-05-2010 1:39 PM
Quote I have already mentioned that my previous supplier was NON LLU......ie using BT equipment such as yourself, so your argument just doesn't hold up.......
I've already apologised for that mistake.
I'll keep you posted as to what's happening with getting the banded profile removed.
Re: Migration Query
12-05-2010 1:40 PM
Quote from: win7xp Adam
Read the posts.
The OP said ".all of these are much lower than my previous non LLU supplier"
You are trying to make out he was previously LLU
Hi win7xp....
Thanks for your support and pointing that error out......
Re: Migration Query
12-05-2010 1:46 PM
I've already apologies for that mistake.
Apology accepted.....
Banded profile is yet another mistake I have to put up with, with no idea when it will be sorted.....
Re: Migration Query
12-05-2010 2:06 PM
B.
Re: Migration Query
12-05-2010 2:11 PM
Plus I wasnt on a banded profile with my previous NON LLU supplier and they use the same BT equipment as plusnet.....which before you mention it was also on ADSL2
Re: Migration Query
12-05-2010 2:32 PM
Quote from: dogwhisperer As we are clearly not in agreement here and you are back tracking from what you promised to do, shall we see what the following organisation makes of it when I can show them that you have clearly broken your code of conduct.....
This part of the code of conduct I found interesting........
2.4 Honesty
2.4.1 Members shall use their reasonable endeavours to ensure Services (excluding Third Party Content) and Promotional Material are not of a kind that are likely to mislead by inaccuracy, ambiguity, exaggeration, omission or otherwise.
2.5 Fair Trading
2.5.1 In their dealings with consumers, other businesses and each other, Members must act fairly and reasonably at all times.
I would argue that trying to back track from a promise of fixing all the issues is not acting fairly and reasonably, along with trying to insist on a further BT visit to my house when there have been 6 separate such visits in the last 6 weeks and BT have already told plusnet that they have unfinished work on the e-cabling, lift and shift and the line card, which clearly has nothing to do with anything in my house which has been checked many times already and taking into account that I am disabled and my health is poor which plusnet seem to ignore and carrying on putting me under unnecessary / avoidable stress by constantly arguing with me and picking holes in what I say, I have explained on several occasions before that I suffer from a serious condition that does not respond well to stress........ so again that does not sound fair and reasonable to me.....
With regards to 2.4.1......there has been a catalogue of misleading and inaccuracies.
Re: Migration Query
12-05-2010 5:17 PM
If no response is forthcoming from them tomorrow morning I will be chasing this up with our BT account manager again. The banded profile will be accounting for the drop to 1500kbps so we do need to clear this before proceeding with any engineering works.
Re: Migration Query
13-05-2010 3:55 PM
Whilst this is going through the high level escalations team have agreed to dispatch an engineer to check the E side (exchange to cabinet) and D side (cabinet to premises) cables and also perform a lift and shift onto pairs which were previously identified as being able to support a slightly increased synchronisation speed to what is being achieved at present.
This should be happening tomorrow and is being done without a visit to your premises so I will keep you updated in detail. Following this its likely an appointment to visit your premises will be requested.
Re: Migration Query
13-05-2010 4:00 PM
Every time so far, 6 in total when you have told me a BT engineer will not be coming to my house, they have turned up at my house every single time.....
What have you done this time to guarantee that BT will NOT turn up at my house tomorrow?
Re: Migration Query
13-05-2010 4:13 PM
Also rather than this being booked in the same way as previous engineers a senior BT openreach engineer and also an engineer coach will be carrying out the work involved. They have been briefed on the history of the issue and I have reiterated at length today the importance of completing this work without a visit to you first.
Adam.
Re: Migration Query
14-05-2010 9:41 AM
Re: Migration Query
14-05-2010 5:31 PM
Also seem to still be on the banded profile.....
Re: Migration Query
17-05-2010 1:05 PM
Yes, you are still on a banded profile at the moment, negotiations are still going ahead to try and get this removed for you.
