Member Centre - not working with firefox
RadioFox
When I visit the Home page of the Member Centre & click on "View Bills" or "View Calls", I am presented with a blank page. I still see the header & footer, but in between is just white space. I tried IE & Chrome. They both display correctly.
Could you fix the site to work with firefox. It's my browser of choice & I haven't had any problems with it on any other sites. It's the latest update. ver. 64.0 (32 bit).
9 REPLIES 9
BrightonRock
Fixes: 8
Re: Member Centre - not working with firefox
Working here - albeit rather slowly - with Firefox 64.0. Do you have noscript or something similar switched on?
RadioFox
Don't have noscript turned on. I do have Adblock Plus installed. I tried switching it off, but it made no difference.
BrightonRock
Fixes: 8
My Firefox is 64 bit, but I would be surprised if that difference were significant, and this is Windows 10. Try Firefox safe mode?
RadioFox
Just tried safe mode. Still the same.
There are other options I could try later, such as Refresh, (which would put firefox back to it's original installation state), clear cookies & cashe, or uninstalling/reinstalling firefox.
btw...I'm running Windows 7 Home Premium 32bit. I don't have any 3rd party firewall programs installed & I'm using Microsoft Security Essentials as my antivirus.
Fixes: 480
I'm on Firefox 64.0 (64 bit) running on a Win 10 computer. It's not working for me either but it's OK using Edge.
BrightonRock
Fixes: 8
How very odd. Still working (slowly) for me using Firefox 64.0 (64 bit) on my Win 10 box; tried it just now.
Surely this has to be an issue with add-ons or their settings? I'm using Ghostery & Ublock;  @RadioFox is using Adblock; what adblocker are you using @Baldrick1?
RadioFox
I have manually disabled Adblock Plus in Extensions. I've also disabled "OpenH264 video codec", "shockwave flash", & "Widevine content decryption" from Plugins. Theme is set to default. Still not working.
Chrome still works OK with Adblock Plus installed & running..
RadioFox
Ahh...I should have had a closer look at the other threads on the forums. Looks like this problem has been going on for nearly 4 months now, and still not resolved, as per this 33 page thread:-
 https://community.plus.net/t5/My-Account-Billing/Cannot-view-bill-in-new-billing-system/td-p/1566790
 After all this time it doesn't look like anything will be done about it now. I'll just have to use a different browser for the Plusnet site, despite FF working perfectly everywhere else.
Strat
Fixes: 565
Moderator's note:
Thread locked in favour of the larger one linked above.
