MY Plusnet broadband Order
adele1
Hi, Can you please help me out here please. I subscribed for Plusnet bb . I was initially told that that my bb service was due on 21/11. I later received a message telling me my bb order is due to complete on 23/11. when i did not receive from Plusnet i chatted with Customer service who told  me supplier have started manual intervention and the order has been assigned to relevant department to clear the order and activate my services on 27th.. i feel I am being played around. Can moderator please let me know what is going on sincerely.
20 REPLIES 20
Strat
Fixes: 565
Re: MY Plusnet broadband Order
Moderators are just customers with no access to your order.
You need a Plusnet CRT member to have a look.
That could well be tomorrow at the earliest now.
adele1
My broadband  order was complted yesterday. It was set up as instructed. However, the security lock is still on despite the connected it is showing therefore I cannot log into internet. Any suggestions on what to do please.
adamwalker
Fixes: 223
Hi adele1,
Sorry to hear about the issue and thanks for reporting a fault with us, our faults team will be responding to that soon.
I'm not sure exactly what you mean about this, please let us know in further detail in case that's an issue on your side we can help you out with.
 Adam Walker
adele1
Hi and thanks for your reply. What I mean by security lock is by the network connection which shows connected, there is a locked black padlock by it. I suspect that means I am not connected to the network. It also says Limited connectivity.
adele1
What is the meaning of network does not give internet access please.
rongtw
Fixes: 12
Have you checked your Firewall settings ?Huh
adele1
should the firewall be off or on pls. I also received a message saying connection between your access point router ------- and internet is broken.
rongtw
Fixes: 12
It should be ON but make sure its allowing your connection
adele1
Hi it is ON but not allowing me connection to the internet still.
rongtw
Fixes: 12
Hi  have a look here  Wink
http://windows.microsoft.com/en-gb/windows/understanding-firewall-settings#1TC=windows-7
adele1
Hi,Thank you for your reference.  I have opened the website and everything suggested is already done. I keep receiving the message connection between your access point  router or cable modem and internet is broken. I am getting to frustrated. Can the problem be coming from the exchange line?
Fixes: 388
Hi adele1
No-one appears to have asked the question, but how are you trying to connect? I suspect from what you have said that it is wirelessly. IF so, can you connect using the ethernet cable and see if you can get online that way?
If you can, it strongly suggests that your wireless settings are wrong.
adele1
Hi
I did try connection as suggested, still no internet connection. You are right, the connection is wireless. I am using dongel at the moment and it is connected through mobile broadband, but Plusnet is showing under wireless.
Fixes: 388
OK, in that case I'm afraid I can't think of anything else to try at the moment, so I'll have to leave you in the hands of PlusNet. Sorry.
