Linux won't work with PN?
Wheel_nut
Re: Linux won't work with PN?
Hi Chris,
That is much clearer. However, some Router settings are best (safest) done using an Ethernet wired connection so you may want to state that support may require a wired Ethernet connected Browser.
Heloman
Hi Chris,
The wording you suggest seems much better. Thanks.
One day PN might be enlightened enough to employ someone who knows the codeword "Shibboleet":
http://xkcd.com/806/
Smiley
jelv
Fixes: 10
I know Plusnet has plenty of those, it's just that they come anywhere near the phones!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
