Legacy accounts
- Feedback
- Plusnet Feedback
- Legacy accounts
Legacy accounts
28-03-2012 6:49 PM
Been With plusnet for about 8 years with no real problems until now!
I am a plusnet premier customer paying 21.99 a month which includes off peak unlimited time between 12.00pm and 4.00pm.
This sounds great but peak time usage starts to deteriorate after I reach 13 gig. . Restrictions applied after 4pm are now starting to really Anoy me. These pathetic warnings that i have used 13 gig of my peak time allowance are becoming a real pain.I am willing to pay to upgrade but "why should I ? " I am an orange mobile customer and Can have unlimited broadband for less than plusnet. Why can i not use iplayer when i return home from work without getting another warning!!
Tell me why I should not move?
Keith.
Keith.
6 REPLIES 6
Re: Legacy accounts
28-03-2012 10:10 PM
depends on how much you use between 8 am and 4 pm, you could get Extra with 60 G for about the same price
Re: Legacy accounts
29-03-2012 2:22 PM
Hi Keithivan,
I'm afraid Premier is now a much older product and as such just isn't designed for the kind of usage that's prevalent these days. As pierre says, you'd most likely be a lot happier on Extra (it's cheaper than premier with a much more generous allowance) even given the shorter off-peak hours.
If you like you can request it and try it for a month, if it turns out it isn't working for you we can move you back to Premier if you prefer?
Re: Legacy accounts
02-04-2012 6:13 PM
Thanks for the reply matt. Only reason I am holding back is the hassle I now face with email etc. 10 years with plusnet (nott 8 as I previously said)
A 60 gig allowance will probably end up in me paying about £100 per month due to £5 per 5 gig over the allowance. I am at present paying over £40 per month for broadband and unlimited calls to landlines. Getting warnings after 11 gig of peak time use is now becoming unusable . Sad day but mac code request looks likely after 10 fault free years.
Re: Legacy accounts
02-04-2012 7:15 PM
if you are currently on 20G peak and you moved to 60G peak, why should you need a lot of extra
you still get unlimited from midnight to 8 am
Re: Legacy accounts
03-04-2012 9:05 AM
Hmm, see what you're saying about the off peak usage from having a look, but are you sure it wouldn't be worth a try? As Pierre says usage between midnight and 8am is still free, I don't know when you're using the majority of bandwidth but if it could be made to fit we wouldn't have any problem with it continuing at the same sort of level.
Re: Legacy accounts
03-04-2012 2:04 PM
Thanks for all the advice guys.
Spoke to Plusnet customer services this morning. They have now been able to transfer my broadband product to one that meets my requirements!
Well done plusnet now looking forward to my 11th year online.
jim:blue I know you are happy but ecessive smileys removed as per Forum Rule mod:end
