Leaving due to RUBBISH Yorkshire service
- Feedback
- Plusnet Feedback
- Leaving due to RUBBISH Yorkshire service
15-08-2013 10:44 AM
Their search heading says "Plusnet | Fast, cheap, reliable Broadband and Phone packages", which is nothing but a lie. They should be fined for false advertising!
My advise get rid of this BT and Yorkshire useless rubbish.
Re: Leaving due to RUBBISH Yorkshire service
15-08-2013 10:50 AM
Ok, something is definitely wrong here. You shouldn't have been given 2 replacement routers. If your line is dropping, it's far more likely to be a wiring fault in your house, dodgy microfilters or a fault on your line!
Let's try and get this sorted!
This image definitely shows you have a problem:
Ex-Plusnet Jobsbody
15-08-2013 11:05 AM
15-08-2013 11:12 AM
I have carried out all the tests plusnet recommends time and time again until I am blue in the face!
I have even replaced the BT box into the house and still it bombs out on me.
I have removed all other extensions and telephones but the issue is unresolved.
i am extremely fed up with the service from BT Plusnet.
15-08-2013 11:15 AM
Quote I have checked out the line with BT (more times than I care to remember) and they say nothing is wrong with it.
BT can only test the voice part of the line, if it's a fault with the broadband then they won't see it.
Quote I have carried out all the tests plusnet recommends time and time again until I am blue in the face!
I'm not asking you to do the tests again, I can see you've done them. If you go through the fault checker just answering the questions we'll take it from there.
It's very likely the the fault is external to your premises, so an engineer is needed to test from your house back to the exchange. Without this the fault is likely to continue and very likely to move to another ISP as they'll be using the same copper wire as we do.
15-08-2013 7:37 PM
15-08-2013 7:59 PM
dick:quote
15-08-2013 8:21 PM
However in PN defence.. i am with PN now for several months and find the broadband fantastic
and the router,, the wi-fi expecially is so good,,
15-08-2013 8:35 PM
3 routers, all supplied by Plusnet, I have done numerous tests and at least on one occasion the BT engineer has come out to sort the problem. My line still goes down so it has to be Plusnet that is the problem. I have forgotten the number of times I have completed their useless testing and been told that it is BT's fault.
I have been in touch with BT today and they have confirmed that there is no fault on my line, that it is Plusnet.
Are you aware that Plusnet is owned by BT? They are just passing the buck due to the appalling and constant bad service that is offered.
Some days my line may only go down a few times, but lately it has been dropping 12 times a day.
I have had enough and I want out of this wretched company.
15-08-2013 8:38 PM
That is impossible.
All BT are doing is trying to get a new sale.
15-08-2013 8:40 PM
PLUSNET IS OWNED BY BT!
15-08-2013 8:43 PM
BT can't just pop into the PlusNet office and have a shifty through your files.
It is IMPOSSIBLE for BT to know if you have a faulty line or not, unless you are a customer of theirs. Hell, BT can't even diagnose problems for their own customers!
15-08-2013 8:44 PM
The Balance
2 Pinfold Street
Sheffield
S1 2GU
15th August 2013
Dear Sirs,
I am totally fed up with your rotten lies and evil excuses about the poor quality of internet service you have provided me with over the past two years.
I have therefore decided that the time has now come to leave your company and go elsewhere.
I demand that you supply me with a MAC code within the next 7 days with out any further excuses. This can be sent to my email address at (blanked out).
You will note that I am sending a copy of this letter to the Ombudsman Services, The Brew House, Wilderspool Park, Greenall's Avenue, Warrington, WA4 6HL
I do hope that you will promptly reply with my MAC code so this matter does not have to go any further.
Yours faithfully
We will see how long it takes Plusnet to give me my MAC Code.
15-08-2013 9:12 PM
I don't see what the problem is - Have you raised the fault again yet?
Plusnet fault's team are one of the best (if not the best) there is. There is so much knowledge in that department it's unreal.
If you can't be bothered to raise a fault for them to look at it, then I think it's a bad job.
You complain of rubbish service, you get offered help, you pretty much ignored it up to now.
If you're in a contract you'll be liable for the fees.
All it takes is a few minutes of your time to run through the http://faults.plus.net system and then Chris has kindly said he will get it sorted out for you.
Just my 2 cents,
Cheers,
Matt
15-08-2013 9:17 PM
Quote from: Mattz0r flyerdave,
Matt
Matt, I have raised a fault many times over the past two years and I am no further forward so I have lost my patience with Plusnet and I now want out. My contract was for 12 months which ended sometime ago.
