Lack of understanding.
adamwalker
Fixes: 223
Re: Lack of understanding.
No worries Ann! Yes, I've fixed that going forward too by making sure the right discounts are in place. I've credited that off for you, as the next bill is due within 24 hours it means that it's going to appear on the February bill as credit instead.
 Adam Walker
Gothiccouturier
Dear Adam,
Thank you so much for that. Is the bill due tomorrow, going to be the correct amount, or the higher amount that December's bill was? Thank you again for your help.
Best wishes
Ann
adamwalker
Fixes: 223
It should be at the correct amount, it's just too short notice to add credit in, do shout up again if there's any issues though.
 Adam Walker
Gothiccouturier
Dear Adam,
Thank you ever so much for all of your help. I really do appreciate it.
Best wishes
Ann
adamwalker
Fixes: 223
No problem at all Ann! Feel free to give me a shout on here any time!
 Adam Walker
