Is mybroadbandspeed broken or not?
kmilburn
Re: Is mybroadbandspeed broken or not?
The results are stored in a cookie on your system, assuming you're accepting cookies, not using private browsing, etc.
Jaggies
I am accepting cookies, and if I go in to Page Info in Firefox Tools menu I can see the cookie is there.
However, it seems to be OK in IE10:
It also works in Chrome, I now have 3 logged results, but they still don't show in Firefox.
wykehamhouse
And now the sign's gone again. FIXED?
artmo
Aspiring Champion
Why not use a different speedchecker?
jelv
Fixes: 10
Fixed - really?
Given that both use the Ookla engine they should be the same.
I'm on 20CN - has anyone on faster connection done a comparison?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Devonian
Fine for me. Smiley
jelv
Fixes: 10
Hmmm...
If nothing else I'm finding that it isn't consistently serving up the image with the results which is in my last post!
Devonian
Very strange.  I'm using chrome on windows 8 if it helps.
w23
Fixes: 4
Bit inconsistent:
Call me 'w23'
jelv
Fixes: 10
What speed do you get from other testers?
w23
Fixes: 4
Not sure what others are seeing in my post above but there are two MBB images.
The second one (58Mb/s) is fairly consistent with other testers, the first one (46Mb/s) is not.
Direct links in case others are having the same 'disappearing graphics' problem as me:
http://www.mybroadbandspeed.co.uk/results/197610791.png
http://www.mybroadbandspeed.co.uk/results/197610861.png
Just run a few more in quick succession (nothing else running here):
Today 08:57 56326 kbps (7.04MB/s) 15880 kbps (1.99MB/s)
Today 08:56 45697 kbps (5.71MB/s) 16353 kbps (2.04MB/s)
Today 08:56 41202 kbps (5.15MB/s) 15593 kbps (1.95MB/s)
Call me 'w23'
