Is mybroadbandspeed broken or not?
wykehamhouse
For a while the message 'Sorry - My Broadband Speed is currently experiencing technical difficulty and may display misleading test results. Thanks for bearing with us while we fix things.' disappeared, but now it's back. It seems to work fine (it gives accurate results) so what's with the message?
25 REPLIES 25
Devonian
Re: Is mybroadbandspeed broken or not?
I was wondering that to, It's been like it for months!
Shhh ! don't tell everyone !  Wink
That site has been giving me the MOST accurate speed test results for months now !  Smiley
Roll_eyes
wykehamhouse
Any response Plusnet?
Kelly
Fixes: 9
Still broken.  The network the box is on isn't scaled for multiple Fibre speed tests.
Kelly Dorset
Ex-Broadband Service Manager
artmo
Aspiring Champion
It's working fine for me.
picbits
It sometimes gives me the correct results, other times it is wildly out.
Date Download Speed Upload Speed
Today 17:11 39759 kbps (4.97MB/s) 16957 kbps (2.12MB/s) Share
Today 15:57 24704 kbps (3.09MB/s) 15558 kbps (1.94MB/s) Share
wykehamhouse
Plusnet, if you think it's broken, surely it would make sense to just take the site down altogether? Then when it comes back we can know for sure that it is fixed.
artmo
Aspiring Champion
Seems to be working fine Smiley
Jaggies
It doesn't seem to be logging results.
Mattz0r
Well, in the space of an hour, it's gone from giving full speed results, to ... not so great results lol - Upload is consistently great though.
Strat
Fixes: 565
Mine gives a very close match to www.speedtest.net.
I also get near identical results to http://speedtest.net
Mattz0r
Quote from: purleigh
You're not on Fibre though, so it's less likely to affect you.
Jaggies
I've done 4 tests, 3 when I posted earlier, ond one a few minutes ago. All with expected results (not on fibre), but they aren't saving for me.
