Impossible to raise ticket on website.
- Feedback
- Plusnet Feedback
- Impossible to raise ticket on website.
17-09-2015 7:42 PM
The only options I ever get through the "Contact Us" option of the support site is a greyed-out chat option and phone.
I only want a profile reset and to ask about any options for increasing upload speed through changing the frequency split. (I tend to upload more than download for streaming/youtube uploads etc, so something like Annex M for Fibre would be nice.)
Re: Impossible to raise ticket on website.
17-09-2015 7:43 PM
17-09-2015 7:49 PM
Awesome, now why couldn't I find this by myself x_x I understand wanting to gate out the common support questions, but making it hard/impossible for people to e-mail them is just... meh
dick:quote
17-09-2015 7:56 PM
<sarcasm>... nevermind. </sarcasm>
18-09-2015 9:41 AM
18-09-2015 11:52 PM
There's no such thing as Annex M on FTTC I'm afraid. It's a completely different way of allocating frequencies on the line, and quite complex intermixing of downstream and upstream ones. Here are the frequencies on my line
Quote Discovery Phase (Initial) Band Plan
US: (7,32) (871,1205) (1972,2782)
DS: (33,859) (1216,1961) (2793,3970)
Medley Phase (Final) Band Plan
Each pair inside brackets are the start and end of a range.
Annex M on ADSL2+ simply doubled the width of the upstream frequencies and lost them from the downstream. Which is why on longer lines it could cost 2.5Mbps of the downstream but didn't give much extra upstream because of the low power from the user modem/router.
You may ask why a band couldn't be swapped on FTTC. I don't know, but I do know that to get the much higher speeds of VDSL2+ there's an awful lot of power management and frequency choices to minimise crosstalk and the like wrecking ADSLx circuits in close proximity. The same sort of reason as that which prevents EO lines getting FTTC until an external cabinet is put in place, as the problem is far harder to solve inside the exchange. (Plus of course, many FTTC cabinets are fed the broadband from a different exchange from the PSTN).
If I'm not mistaken the frequency ranges are internationally determined anyway. It isn't really under BT Group's control.
22-09-2015 11:01 PM
adie:quote
23-09-2015 11:55 AM
Unfortunately we can't remotely reset FTTC profiles and in your case it wouldn't make much difference I'm afraid.
Your profile is "0.128M-74M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off" and your sync speed is 67.5 mbps.
23-09-2015 12:41 PM
Quote from: Matthew Unfortunately we can't remotely reset profiles and in your case it wouldn't make much difference I'm afraid.
Believe that only strictly applies to FTTC (Fibre) as in this case but may not apply to ADSL.
Basically your profile should not be causing ANY restriction, just your sync speed.
Quote from: Matthew Your profile is "0.128M-74M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off" and your sync speed is 67.5 mbps.
@Matthew, do you have the Upstream sync since you've provided everything else?
23-09-2015 1:12 PM
Post edited
The upload sync is 19.7.
23-09-2015 4:41 PM
I'm worried about restarting my modem to try and shift sync speed though as BT's equipment treats that as a fault and ends up lowering your profile/sync I'm told.
As far as my ticket is concerned, all I got was this:
Quote Dear Miss X,
Thanks for taking the time to contact Plusnet.
We're making some changes to the way we handle our customers questions. So, we’re not able to answer your question in this way but we’d be more than happy to help you quickly and easily though Plusnet Chat.
Just follow the link below to chat to us online and we’ll do all we can to help.
https://www.plus.net/home-broadband/contact/
There is no need to reply to this ticket if the matter is resolved. If you wish to close this ticket you can do so via the following link: Close This Ticket. Alternatively it will automatically close in 14 days.
However, if you feel the matter needs further investigation do not hesitate to get back in touch on 0800 432 0200 from a Land line and 0345 140 0200 via Mobile if we can be of any further assistance.
Which is just unacceptable. Especially after I already spent 30 mins on hold one evening trying to get through because the chat service is never available when I try and use it. How hard would it have been to say what Matt did above? Would waste less time overall to give an answer of "We can't reset profiles on Fibre products" than to continue a merry-go-round.
