IP addresses not UK - Can customers please report any problems here
- Feedback
- Plusnet Feedback
- Re: IP addresses not UK - Can customers please rep...
Re: IP addresses not UK - Can customers please report any problems here
06-09-2015 11:10 AM
No error message; the connection just times out. PlusNet Safeguard is off.
Suggestions?
08-09-2015 12:59 PM
Quote from: atiras I can't access the National Lottery site -- I have a static IP address 81.174.159. xxx. The problem only started after I moved to PlusNet...
That's not going to be related to the issues being discussed in this thread. Might be worth starting a fresh topic if you're still having problems.
Quote from: jjc 146.199.71.233 was still being shown as "infonet" on speedtest.net the other night
It probably will. That's who the range is registered to. The site should correctly identify you as being in the UK though? I'll contact speedtest.net but this is purely an aesthetic problem.
Edit: Got pointed to the form here, so I've submitted an ISP amendment request for all four ARIN ranges.
25-09-2015 1:19 AM
Also if it is their entire system then potential customers customers could get a downside by Vidahost's customers website telling their customer that they are from the US (yes a chain reaction lol)
Either way, it's a fault. Hopefully it can be sorted out.
26-09-2015 7:13 AM
26-09-2015 10:59 AM
30-09-2015 2:15 PM
Quote from: thedyes0 The cPanel Backup at Vidahost.com shows my IP as INFONET Services Corporation, United States. Maybe you could drop them an email Bob explaining what is what because it's just a pesky annoyance being told your IP is from USA or checking last logged in IP and seeing USA which is a little worrying.
Done.
Quote from: Bob
I've since received confirmation that this should now be resolved.
30-09-2015 3:18 PM
Quote from: Bob
Done.
Whilst it's hardly relevant, Vidahost have asked me to confirm the main domain that's associated with your cPanel account. Would you mind PM'ing me the details?
05-10-2015 8:37 PM
Just rebooted router, now got that dam 146.199.x.x address !
So playing MW3 (PC), means the game thinks I am in the US, and the players I pull in when I become host is mainly US, Canadian, and south American, which means they all get bad lag, and the game sometimes doesn't lock onto Euro players
Same applies when searching for servers in L4D2 (PC), it finds US servers, so I get laggy play (ping of 100+)
And same for Titanfall, finds regional games in the US....
Makes my 66mb fibre seem pointless !
Not moaning, cos I know a few reboots will get me a UK Geo IP, but even still, with a 46.x.x.x address, I still attract US/South America/Australian/NZ players ! Grrrrrrrrrrrrrrrrrrrrrrrrr !
06-10-2015 10:21 PM
Matchmaking in games is a strange art, evidenced somewhat by what your seeing. I presume Activision would have some bearing over how MW3 behaves and I don't hold much faith in being able to get in touch with somebody there that has any influence over these things?
Left 4 Dead is an odd one though. Isn't that developed by Valve themselves, who are also responsible for the Steam client? I'd have thought you'd experience the same problems with currency etc. in the store too if Valves games think you're based in the US. Perhaps the two don't rely on the same geo-location logic though?
14-10-2015 7:56 PM
My system says I have these IP addresses:
192.168.1.65 (which has usually be the case) but now it also shows External IP address as 80.189.83.25
This problem may have cost me a fortune! WTF is going on?
14-10-2015 10:40 PM
I think Bob will need to look at this but it sounds to me like an issue at the National Lotttery as here is the info about the IP address range in which your IP address falls -
% This is the RIPE Database query service.
% The objects are in RPSL format.
% The RIPE Database is subject to Terms and Conditions.
% See http://www.ripe.net/db/support/db-terms-conditions.pdf
% Note: this output has been filtered.
% To receive output for a database update, use the "-B" flag.
% Information related to '80.189.68.0 - 80.189.89.255'
% Abuse contact for '80.189.68.0 - 80.189.89.255' is 'abuse@plus.net'
inetnum: 80.189.68.0 - 80.189.89.255
netname: BV-ADSL-POOLS-1
descr: RB ADSL
country: GB
admin-c: BR431-RIPE
tech-c: BR431-RIPE
status: ASSIGNED PA
mnt-by: BVUK-MNT
mnt-lower: BVUK-MNT
mnt-routes: BVUK-MNT
created: 2006-06-27T08:52:37Z
last-modified: 2006-06-27T08:52:37Z
source: RIPE # Filtered
role: Brightview ROLE
address: The Balance
address: 2 Pinfold Street
address: Sheffield
address: S1 2GU
abuse-mailbox: abuse@plus.net
admin-c: SB195-RIPE
admin-c: DS3916-RIPE
tech-c: SB195-RIPE
tech-c: DS3916-RIPE
nic-hdl: BR431-RIPE
mnt-by: BVUK-MNT
created: 2002-08-07T17:29:51Z
last-modified: 2015-04-21T14:49:04Z
% Information related to '80.189.0.0/17AS6871'
route: 80.189.0.0/17
descr: BV-PS-GR
origin: AS6871
mnt-by: BVUK-MNT
mnt-lower: BVUK-MNT
mnt-routes: MAINT-AS6871
created: 2011-08-09T16:31:52Z
last-modified: 2015-04-21T14:39:38Z
% This query was served by the RIPE Database Query Service version 1.80.1 (DB-3)
Definitely UK. The quickest solution to this is the log into the router, select 5.4 Advanced Options and go to the Broadband Connection box and click "Disconnect" to drop your PPP session (this is not your sync). Wait about 30 seconds and then click connect to start a new PPP session. You should now have a new (different) IP address.
I'm intrigued as to why you think it might have cost you a fortune, don't you have six months to claim any prize you may have won?
14-10-2015 10:52 PM
15-10-2015 12:00 PM
Quote from: CroydonGeorge Today I tried to sign in to the Lottery but their system said my IP address shows I am not in the UK .
I think the problem is more likely due to the IP you had earlier this morning, which was in fact 146.200.20.199.
Having said that, I've tested this range before, and I've never been able to replicate a problem with the National Lottery's website
The next time this happens to somebody, it would be very useful if you could screen capture the error.
03-11-2015 11:24 PM
04-11-2015 12:12 AM
- Feedback
- Plusnet Feedback
