How do you view open questions?
Lakin
Openreach failed to upgrade my line yesterday, hence I have been on the Plusnet site looking for support.
Plusnet support is generally quite good in my experience but I find the support website hard to navigate - Jess gets up my nose.
I wonder if anyone can tell me the direct link to the page that shows my open / closed questions?
I have bookmarked - https://portal.plus.net/wizard/?p=search, and this seems to work, but I cant find a proper link on the Plusnet site for this page.
rongtw
Fixes: 12
Re: How do you view open questions?
ITS hidden by PN  Cheesy
so most cant find it , a lot of regulars here have it on their Sig so its easier to find  Wink
Fixes: 10
Quote from: Lakin
I find I can access them easy enough by clicking on "Member Centre", then on the left hand pane under "Useful" links the top one is "View your questions".  That in turn gives a page with your open tickets.  By the way it's worth selecting Show closed questions in the last 7 days if you have an open fault, because sometime relevant information is added as a new ticket which is immediately closed.  (What I do in those cases is paste the update into the main open ticket, so all the history is in one place)
You could try this direct link, I'd be interested to see if it works ... https://portal.plus.net/wizard/index.html?p=search&view_by=7days
Fixes: 10
That link is good.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Cheers.  The actual URL included some extra stuff on the end which I thought might be hard-coding the 7 day search to specific dates, although looking at it again maybe not .. (&from=dd%2Fmm%2Fyy&to=dd%2Fmm%2Fyy&x=29&y=11).
Lakin
Quote from: aesmith
Quote from: Lakin
Thanks aesmith, exactly what I was looking for. How did I not see itHuh
