How Long Does It Take !!!!! Ticket 31405747 HELP
- Feedback
- Plusnet Feedback
- Re: How Long Does It Take !!!!! Ticket No30495258
15-12-2009 5:13 PM
28-12-2009 7:19 AM
28-12-2009 11:39 AM
Because of either disconnections or excessive errors the BT equipment has pushed your target up 3db at a time to try and find a level at which the line performs acceptably.
If you cure the cause of the errors or disconnections it will fall again.
28-12-2009 3:31 PM
cheers
28-12-2009 4:46 PM
Have you used the quiet line test to check if the noise has returned on the line?
29-12-2009 9:35 AM
30-12-2009 9:38 AM
Quote as i said previous i have done EVERYTHING asked now it's time for plus net to sort it !!!!!!
I've just checked your account, but there isn't an open ticket nor has there been one since October?
Your profile on our side and BT's side is now set at 1750, which should give speedtest results near 1500. It's worth keeping in mind that the linechecker results which said 2.5Mb-3Mb aren't a minimum expectation, but an estimate based on the length of your line.
30-12-2009 10:50 AM
No there is no open ticket 'cos no action was taken on the ticket and the help i have been gettting is from this forum by yourself, mand & james, so i was under the impression this was the way to get it sorted as reading other post it seems if you post on rant & raves something gets done. Sorry if i have been getting the wrong impression of how things are done. After all of what looks to me like wasted time by me and your team to get a speed of what is quoted and what i believe i should be getting are you saying i am getting the max speed available ?
If this is so and i get an independant broadband expert to check this out and get a different story what happens then ?
31-12-2009 2:48 PM
31-12-2009 2:57 PM
I think the next step would be for us to request a reset of your target SNR as you've checked all your internal wiring and that doesn't appear to be causing any issues. This reset effectively starts your 10 day training period again and allows the line to recalculate the best values possible.
Let me know if you've like me to do this and I'll request it this afternoon.
We normally asked for a fault ticket to be open on an account so we can keep easy track of everything that's been going on and so our faults team can actively investigate, just posting on the forums means our faults team are unlikely to ever see your issue.
31-12-2009 3:59 PM
02-01-2010 3:11 PM
04-01-2010 10:53 AM
Going over the previous replies to this thread you have said that you tried the socket behind the master socket, is that where you are still plugged in? If not can you plug it back in there and let me know so I can run a quick line test to see if anything changes?
05-01-2010 6:23 AM
I have re plugged the router in to the master socket so test away !!!!!!!!!!!!!!!!
05-01-2010 9:12 AM
- Feedback
- Plusnet Feedback
