Help and Support - Link to service status fails
Fixes: 62
https://www.plus.net/help/ and clicking on Service Status at the bottom gives this in Firefox
But it works in Internet Explorer
This is the failed link https://www.plus.net/supportpages.html?a=2&%2525252525252525253fhelpheader=servicestatus
This is the successful one http://www.plus.net/supportpages.html?a=2&%3fhelpheader=servicestatus
Fixes: 37
Re: Help and Support - Link to service status fails
It was clicking links just like these that got my IP banned click with caution!
Fixes: 173
@Oldjim
Just a couple of minutes ago I had the same issue.
http://portal.plus.net/supportpages.html?a=2 works.
Customer and Forum Moderator. Windows 10 Firefox 63.0.3 (64-bit)
Fixes: 37
These pages (can) contain cyclic redirect code and as a consequence they hammer the servers looking up their own behinds. This then triggers an alarm that for me resulted in a ban! Sad
Fixes: 37
No reply from @Oldjim yet, maybe he's got himself banned Funny
Fixes: 103
We've a ticket raised on this one and it's being investigated (ref: 96169).
In the interim, I'd suggest against repeated clicks in case you end up on the wrong side of our security systems 😉
PS. If you clear your cookies and avoid any of the mobile pages then I suspect the problem will go away.
Fixes: 12
Plusnet have had a number of these internal routing issues over the years and always seem to struggle in resolving them quickly.
I wonder if some of this cyclic re-routing is the root cause of a number of the recent performance issues?
Maurice
Fixes: 103
Nothing to do with any of the broadband performance issues Maurice.
DS
Fixes: 8
fwiw - Firefox using noscript -> googleanalytics.com and googletagmanager.com blocked plus ghostery and no problems at all here (unless it's already been fixed....?)
Fixes: 10
@bobpullen wrote:
We've a ticket raised on this one and it's being investigated.
... and once banned it seems it's impossible to get it lifted even though it's Plusnet's fault!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
