Help and Support - Link to service status fails
Oldjim
Resting Legend
Fixes: 63
https://www.plus.net/help/ and clicking on Service Status at the bottom gives this in Firefox
But it works in Internet Explorer
This is the failed link https://www.plus.net/supportpages.html?a=2&%2525252525252525253fhelpheader=servicestatus
This is the successful one http://www.plus.net/supportpages.html?a=2&%3fhelpheader=servicestatus
9 REPLIES 9
Re: Help and Support - Link to service status fails
It was clicking links just like these that got my IP banned click with caution!
Strat
Fixes: 565
@Oldjim
Just a couple of minutes ago I had the same issue.
http://portal.plus.net/supportpages.html?a=2 works.
These pages (can) contain cyclic redirect code and as a consequence they hammer the servers looking up their own behinds. This then triggers an alarm that for me resulted in a ban! Sad
No reply from @Oldjim yet, maybe he's got himself banned Funny
bobpullen
Fixes: 327
We've a ticket raised on this one and it's being investigated (ref: 96169).
In the interim, I'd suggest against repeated clicks in case you end up on the wrong side of our security systems 😉
PS. If you clear your cookies and avoid any of the mobile pages then I suspect the problem will go away.
MauriceC
Resting Legend
Fixes: 17
Plusnet have had a number of these internal routing issues over the years and always seem to struggle in resolving them quickly.
I wonder if some of this cyclic re-routing is the root cause of a number of the recent performance issues?
Maurice
bobpullen
Fixes: 327
Nothing to do with any of the broadband performance issues Maurice.
DS
Seasoned Champion
Fixes: 22
fwiw - Firefox using noscript -> googleanalytics.com and googletagmanager.com blocked plus ghostery and no problems at all here (unless it's already been fixed....?)
jelv
Fixes: 10
@bobpullen wrote:
We've a ticket raised on this one and it's being investigated.
... and once banned it seems it's impossible to get it lifted even though it's Plusnet's fault!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
