Heading over to Plusnet from BT
- Feedback
- Plusnet Feedback
- Heading over to Plusnet from BT
29-09-2014 10:53 AM
fibre extra and phone line.
I hope my order to switch from BT infinity 2 goes through smoothly
as I have read some horror stories of this type of order going into
a plusnet processing black hole.
I will keep a check on progress and look forward to having my
Plusnet fibre active soon.
I hope this will be the start of a better service than the one received
to date from the other supplier.
At the moment I am
Re: Heading over to Plusnet from BT
29-09-2014 10:55 AM
Hope everything goes well for you.
29-09-2014 11:23 AM
There were a couple of potential blocks that it is worth checking.
- I gave my MAC online after the order ~ I wanted to get the order in before the Mac arrived because of cashback deal expiry. I then checked with Plusnet telephone service a couple of days after that to make sure things were progressing, and indeed the system hadn't automatically noticed the Mac and moved on to the next step of the process.
- The day of the changeover BT did disconnect their equipment, but the Plusnet connection/activation that should have been automatic almost immediately did not happen.
In both cases the issue was dealt with very quickly and efficiently by the service people. However neither of the calls should have been necessary. I don't know how long it would have been before the Plusnet system resolved them automatically if I hadn't called. The system is clearly far from 100%; also the feedback about your status is not good, very few emails and no way of verifying online.
Good luck with your move.
29-09-2014 11:28 AM
I hope that will avoid your initial issue.
I was hoping that e-mails etc would update often and swiftly but I may need to
call if things appear to get 'stuck'.
I will post here of any issues that arrise as well as any praise that is due.
30-09-2014 10:11 AM
Your account switchover is looking very smooth at the moment. We're all set in for 07/10/2014.
Feel free to let me know if there are any problems.
Matty
01-10-2014 12:15 PM
01-10-2014 2:31 PM
processing for dispatch.
I have been most impressed with the SMS and e-mail updates and at present
just looking forward to a fibre service as good as the support I have received so far.
Well done Plusnet to date and I am still a
I do like to post on good things were possible (as well as bad if needed) in order that
a balance can be kept on the forum - its all to easy to just post when things go wrong !
01-10-2014 4:03 PM
Also the transfer of broadband on the supposed date of transfer could happen at any time during the day
01-10-2014 4:34 PM
with the line remaining in BT's control and once the broadband transfer is complete the
home phone line will be actioned around 2 weeks later.
In fact I don't even have a date for the phone line transfer in the control panel yet.
Where did you get the information it would be the other way round ? or have I mis-read something.
01-10-2014 4:48 PM
Quote from: BlackPearl The information I have is that the BROADBAND will transfer first (in my case on 7/10/2014)
Just to clarify, this is correct. In rare extenuating circumstances it may be the other way round.
I have also replied to your ticket regarding your phone transfer here: 92373009
Matty
01-10-2014 5:23 PM
Thanks for the ticket response also much appreciated.
I will now wait with patience (hopefully) until next Tuesday and the fibre switch over event.
02-10-2014 9:42 AM
02-10-2014 9:54 AM
Quote yet still no BB nearly a week later.
Don't be put off BlackPearl. The vast majority of transfers to PN are, like mine, completely seamless & stress free. Sadly, as in all things in life, on very RARE occasions, hiccups do occur. I'm sure that you'll be as happy with PN fibre as am I.
02-10-2014 10:28 AM
02-10-2014 12:39 PM
