Having a lot of problems with Plusnet!
craigfoxy1
Re: Having a lot of problems with Plusnet!
how long does it take till i get my wireless router? if my phone line got installed on the 9th and my internet goes live on the 18th
Chris
Legend
Fixes: 169
The router is set for dispatch tomorrow so should arrive prior to the install.
pierre_pierre
deleted
craigfoxy1
all sorted  Smiley Im not moaning again lol ive got my xbox and PS3 on thru my wireless router but i cant get my pc on thru wired connection any ideas?
spraxyt
Resting Legend
Fixes: 75
Without any information to go on it is difficult to provide constructive suggestions. For example can you browse to the router?
You might find giving the CSC a ring provides the quickest solution to this problem.
David
orbrey
I'm wondering if you've set a static IP address in your PC's networking properties, and your new router is operating on a different subnet (i.e. 192.168.0.1 as opposed to 192.168.1.1) - could this be the case?
