Gateways being shut down?
- Feedback
- Plusnet Feedback
- Gateways being shut down?
19-09-2016 2:30 PM
As users are moved to the new network they will stop using the old gateways (except those on fixed IPs). I'd expect that there would be a point where PN would shut some of them down.
I've been keeping an eye on which gateways I connect to and haven't seen pcl-bng04 and ptw-bng02 for quite some time. Have they been closed?
Is anyone still on the old network or on the new with a fixed IP on either of those? (http://usertools.plus.net/@gateway to check)
Re: Gateways being shut down?
19-09-2016 3:16 PM
Array
[1] => 7 195.99.126.139 (195.99.126.139) 3.886 ms
[2] => 8 205.core.plus.net (212.159.1.205) 4.122 ms
[3] => 9 407.xe-2-2-2.plusnet.ptn-bng01.plus.net (84.93.248.41) 4.069 ms
[4] => 10 rongtw.plus.com (80.229.) 22.190 ms
You are currently connected to gateway ptn-bng01. and i have a static IP
19-09-2016 3:19 PM
Exactly the same as me.
19-09-2016 7:24 PM
You are currently connected to gateway pcl-bng01
Im also on static ip ![]()
19-09-2016 7:36 PM
You are currently connected to gateway ptw-bng01.
Actually on the new network, but now with a static IP.
19-09-2016 7:40 PM - edited 20-09-2016 10:02 AM
Ste, you are still on New network, just routed to the old 👍
19-09-2016 10:28 PM
New network, static IP.
Which gateway
This is located in Telehouse West.
20-09-2016 9:42 AM
Wasn't there a comment that the "new network/static IP" combination would use the bng gateways? As being on a bng device consistently drops my download by 2Mbps vs an ag gateway, that sort of comment is relevant to me. I'm currently on pcl-ag02 (since 55/10 re-sync on 8 Aug) but don't know which network.
Phil
20-09-2016 10:04 AM
Must admit since PN started moving people across to New ,, The OLD gateways are a lot better
20-09-2016 10:22 AM
Yes, but once everyone is moved across they will need fewer bng gateways.
You must still be on the old.
20-09-2016 10:22 AM - edited 20-09-2016 10:26 AM
For my static connections :
You are currently connected to gateway pcl-bng01.
You are currently connected to gateway ptn-bng02.
@rongtw - I don't know where you got your 'array' from but that looks nothing like an array to me, where did it come from?
Edit:- Static and Second GW
20-09-2016 11:03 AM
@Anonymous
http://users.plus.net/@gateway_custom?debug-ip=yes
20-09-2016 11:11 AM
Oh yes I see where it comes from now, thanks for that. Not trying to be awkward but I still can't recognise it as a 'proper' array. No big deal though, I was just asking because I'm nosey.
