Gateways being shut down?
jelv
Fixes: 10
As users are moved to the new network they will stop using the old gateways (except those on fixed IPs). I'd expect that there would be a point where PN would shut some of them down.
I've been keeping an eye on which gateways I connect to and haven't seen pcl-bng04 and ptw-bng02 for quite some time. Have they been closed?
Is anyone still on the old network or on the new with a fixed IP on either of those? (http://usertools.plus.net/@gateway to check)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
12 REPLIES 12
rongtw
Fixes: 12
Re: Gateways being shut down?
Array
    [1] =>  7  195.99.126.139 (195.99.126.139)  3.886 ms
    [2] =>  8  205.core.plus.net (212.159.1.205)  4.122 ms
    [3] =>  9  407.xe-2-2-2.plusnet.ptn-bng01.plus.net (84.93.248.41)  4.069 ms
    [4] => 10  rongtw.plus.com (80.229.)  22.190 ms
You are currently connected to gateway ptn-bng01.   and i have a static IP
Strat
Fixes: 565
Exactly the same as me.
St3
Aspiring Champion
Fixes: 5
You are currently connected to gateway pcl-bng01
Im also on static ip Tongue
Mustrum
Fixes: 81
You are currently connected to gateway ptw-bng01.
Actually on the new network, but now with a static IP.
rongtw
Fixes: 12
Ste, you are still on New network, just routed to the old 👍
Jaggies
New network, static IP.
Which gateway
This is located in Telehouse West.
PeeGee
Wasn't there a comment that the "new network/static IP" combination would use the bng gateways? As being on a bng device consistently drops my download by 2Mbps vs an ag gateway, that sort of comment is relevant to me. I'm currently on pcl-ag02 (since 55/10 re-sync on 8 Aug) but don't know which network.
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
rongtw
Fixes: 12
Must admit since PN started moving people across to New ,, The OLD gateways are a lot better
jelv
Fixes: 10
@PeeGee
Yes, but once everyone is moved across they will need fewer bng gateways.
You must still be on the old.
For my static connections :
You are currently connected to gateway pcl-bng01.
You are currently connected to gateway ptn-bng02.
@rongtw - I don't know where you got your 'array' from but that looks nothing like an array to me, where did it come from?
Edit:- Static and Second GW
SpendLessTime
Fixes: 86
@Anonymous
http://users.plus.net/@gateway_custom?debug-ip=yes
Oh yes I see where it comes from now, thanks for that. Not trying to be awkward but I still can't recognise it as a 'proper' array. No big deal though, I was just asking because I'm nosey.
