Firefox 52 seems to have broken your website
Fixes: 62
https://www.plus.net/help/broadband/
Non of the links on this page work
jaread83
Fixes: 78
Re: Firefox 52 seems to have broken your website
Works fine for me.
Did you try performing a hard refresh? You might have a cached version of the site and some changes were released very recently.
Fixes: 62
Marked as fixed but it isn't as it goes to the screen you show then goes back to the one I showed
Note I am on the 32bit version
jaread83
Fixes: 78
It did the 'sticking' thing earlier for me too until I did a hard refresh.
I will have to raise it with my team about having some cache busting stuff applied whenever new changes go out. We got the CSS to work in this way but I think that maybe the javascript will need the same kind of treatment.
Fixes: 62
it isn't that a hard refresh takes you to your pic but then reverts immediately to mine
jaread83
Fixes: 78
It works for me but under some certain circumstances it takes a bit longer to load. It eventually works though from what I can see.
I have raised this internally to be looked at asap. Chrome doesn't have this issue as far as I can tell but I will have this tested and get to the root cause of this.
Thanks for letting us know about this so that I could raise this internally.
Fixes: 62
yes it appears that this code is borked
 <div class="question__expander js-expander">
            <h3 class="question__expander-title js-expander__trigger" role="tab"
jaread83
Fixes: 78
Did you try clearing your browser cache or trying it in a private browser session on FF? Do you have any console logs from the FF web developer tools?
Fixes: 62
browser cache is cleared when I close Firefox and inspector doesn't show up anything to my untutored eye
private browsing is the same
BrightonRock
Fixes: 7
@Oldjim
The page seems to be working for me using Firefox 52 (32 bits). Could this be a FF extension issue?
Fixes: 4
All the links work here on 52
Fixes: 62
Seems OK in Safe Mode but one thing is odd - it is loading from Localhost - could it be because I have XAMPP installed
BrightonRock
Fixes: 7
For what it is worth, I don't have XAMPP installed and, as I said earlier, the page works here.
Fixes: 4
Very slow here
Fixes: 62
correction - still broke in safemode
