turn on suggestions
Feature Suggestion
- Feedback
- Plusnet Feedback
- Feature Suggestion
Feature Suggestion
Feature Suggestion
01-05-2015 5:04 PM
hi, just a quick suggestion, would it be possible when there is maintenance on a gateway and the service status is sent round for the notification to show which gateway this is taking place on? I quite often wonder which gateway it is having work done as the service status RSS only says "one of our gateways"
thanks
thanks
Re: Feature Suggestion
01-05-2015 6:34 PM
If it's a single gateway then I/we will generally post which gateway it is. Quite often though we kick people from many different gateways during maintenance and until the time comes we don't know which gateways this is going to be from.
Chris Parr Plusnet Staff |
02-05-2015 7:50 AM
hi chris, thanks for that. I wasn't aware of this
