Feature Suggestion
Danmcclurg
Feature Suggestion
hi, just a quick suggestion, would it be possible when there is maintenance on a gateway and the service status is sent round for the notification to show which gateway this is taking place on? I quite often wonder which gateway it is having work done as the service status RSS only says "one of our gateways"
thanks
2 REPLIES 2
Chris
Legend
Fixes: 169
Re: Feature Suggestion
If it's a single gateway then I/we will generally post which gateway it is. Quite often though we kick people from many different gateways during maintenance and until the time comes we don't know which gateways this is going to be from.
Danmcclurg
hi chris, thanks for that. I wasn't aware of this:)
