Fault reporting - Quickest way - troubleshoot by text
rhohne
The information on how to associate your landline number with a phone or broadband fault appears to have disappeared from the following help pages  https://www.plus.net/help/report-a-problem/phone/#phone and https://www.plus.net/help/report-a-problem/broadband/#broadband
Text PHONE followed by your landline number to 07800008121.                  <----------missing
e.g. PHONE 01234567891 (charge may apply at your standard rate)
Text HELP followed by your landline number to 07800008121.                    <----------missing
e.g. HELP 01234567891 (charge may apply at your standard rate)
5 REPLIES 5
Fixes: 240
Re: Fault reporting - Quickest way - troubleshoot by text
@JonoH  - is this your space?
Fixes: 1,653
As far as I’m aware the text system automatically identifies the right account from the mobile number used, but if it has difficulty then it’ll ask for the landline number.
Fixes: 240
Ouch!!
George Orwell 1984 - Plusnet can associate a mobile number with a landline service … well guess maybe! Wonder what happens if I wanted to use my phone to arrange an automated test on one of my referral’s account?
Fixes: 1,653
I believe you’d be provided with the option to message the landline number of the right account or request a call.
Fixes: 558
Doesnt that assume that the mobile is NOT registered as a contact on ANY account ?
If its regjistered on an account , then isnt it going to assume thats the account to be tested ?
Or does it detect there isnt a faukt and then ask for a phone number ?
