Fault Team Refusing to Call Me Back
- Feedback
- Plusnet Feedback
- Re: Fault Team Refusing to Call Me Back
19-10-2010 1:29 AM
We have added your line to a trial with BT which allows us to disable the dynamic line management system in your local exchange for your line. This means we can choose how your line is configured manually. I have set the line to optimise the speed of the connection and this will cause your sync rate to increase during the course of the next 24 hours. Although the line sync speed will improved immediately once the profile change goes through it can take up to 72 hours for you to notice a difference in speed at your side. This is due to the time it takes for the line speed profiles on both BT systems at the exchange and speed profiles on our network to synchronise. We will now monitor your line to ensure this completes successfully and will contact you to confirm.
Could somebody start treating me with the customer service which you claim to have on your current tv and radio advertising campaigns.
19-10-2010 9:34 AM
I'm sorry to hear that this issue is taking a while to resolve. I'll intervene and do what I can get get some more attention and urgency given to your fault.
After looking at the notes on your ticket I would argue that no one has refused to call you but I can identify at least a couple of points in time where picking up the phone would have been the best thing to do.
I'll begin dealing with your fault now and will ensure someone gets in touch by phone today.
Adam.
19-10-2010 3:18 PM
19-10-2010 11:05 PM
And why, so many days on, has nobody had the problem assigned to them?!
Beware all plunet customers - if you get a fault, the relevant team WILL refuse to take it seriously and WILL NOT call you back as promised.
Disgusting. Absolutely disgusting.
20-10-2010 9:08 AM
20-10-2010 9:32 AM
21-10-2010 1:52 AM
Still no improvement despite the claims.......what have you done to my connection speed?!
21-10-2010 9:16 AM
It looks from your tickets that one of our faults agents has taken personal control of this issue as of the afternoon of the 19th and in fact states that a voice mail was left on your mobile number as well as your land line number at around 6pm yesterday.
Your profile should now have updated as per the other open ticket on your account, sometimes it's necessary to reboot the router in order to pick up the change - have you tried this since the profile updated late last night/early this morning?
02-11-2010 11:27 PM
03-11-2010 10:45 AM
I can see the connection's gone intermittent again, I'm just testing this for you now and will get it reraised. I'll also make sure someone on the faults team takes ownership of this for you.
I'm sorry we didn't pick up on that and will certainly be chasing it with the faults team.
I assume the issue is still the same with the router in the master or test socket and everything else removed from the line? I realise you've tried this before but as the previous fault has now been closed it'll be treated as a separate fault from the last one even if it is a continuation of the same problem, so the same tests are required again I'm afraid.
03-11-2010 12:41 PM
03-11-2010 1:37 PM
dick:red All caps post edited as per forum rules
03-11-2010 1:44 PM
03-11-2010 1:46 PM
As has been mentioned several times on these forums, there's a 5 day timeout on all faults we raise to our supplier (that's not the ticket, it's the fault itself). If we don't advise that the fault is ongoing within 5 days, the fault is automatically closed. As you advised on the 21st October on your ticket that you were satisfied with your speeds of over 8Mb/s the fault has timed out of its own accord I'm afraid.
03-11-2010 2:03 PM
