Exceeded allowance
mrmarkus1981
Exceeded allowance
Good morning, i posted on the 'Broadband and Router' section yesterday but this is a differentr rant altogether!  Angry
I set the maximum limited i could be charged over my allowance to £10, and plusnet have just went and put it up to £15 without my consent.
Please note i will NOT be paying the extra £5 and would appreciate if somebody would rectify the situation.
Thanks in anticipation
Mark
Username : mrmarkus1981
14 REPLIES 14
adamwalker
Fixes: 223
Re: Exceeded allowance
Morning Mark,
I can't be sure why this has happened, but will look into that further. I can't really stop the £5 from going through but I will make sure it gets refunded afterwards.
A data transfer cap is in place now so there should be no extra charges.
 Adam Walker
mrmarkus1981
Thanks Adam
Is my usage to be reset tonight, now my billing date has moved?
Mark
adamwalker
Fixes: 223
Yes it should, however I've just noticed that the extra charges happened due to the way you set the data transfer cap. The total allowed was set to £35.42 that minus the subscription cost is around £17 hence it's allowed an additional 15gb so the charges are correct.
Adam.
 Adam Walker
mrmarkus1981
Im not entirely sure what you mean, it seems pretty straight forward when i look at it....
Maximum extra monthly spend: £10.00
jelv
Fixes: 10
Has your subscription decreased since you set the cap?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
mrmarkus1981
Not that im aware of?
adamwalker
Fixes: 223
Where abouts are you seeing that? the total showing on your account is definitely £35.42 which accounts for the extra 15gb.
 Adam Walker
Oldjim
Resting Legend
Fixes: 63
mrmarkus1981
Pic attached
adamwalker
Fixes: 223
I've just become aware of problem 68280 (data transfer watch mismatch between portal and WP)
So it looks like it is our bad after all, sorry for any confusion.
It's due to be fixed tomorrow so I'll revisit this then for you.
Adam.
 Adam Walker
mrmarkus1981
Adam, can you please check my profile. Ever since i exceeded my usage (now reset) i'm getting less than a 1MB d/l speed
P.S My pings have also been really bad recently, getting my backside kicked on MW3 - not happy Sad
orbrey
Hi MrMarkus,
This is an odd one. You're in sync at over 8000 and your profile on our side is at 7000, which is correct. However I can't get any records from the delta report side of things, not sure why, and a consistency check test is also failing to complete.
What's your profile as shown on a BT speed test?
mrmarkus1981
Seems better today  Huh
Download speedachieved during the test was - 6061 Kbps
Additional Information:
Your DSL Connection Rate :8096 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7000 Kbps
adamwalker
Fixes: 223
I've just run a quick line test and TBH that seems about right for how the line is performing.
 Adam Walker
