Exceeded allowance
- Feedback
- Plusnet Feedback
- Re: Exceeded allowance
Exceeded allowance
28-11-2011 8:04 AM
I set the maximum limited i could be charged over my allowance to £10, and plusnet have just went and put it up to £15 without my consent.
Please note i will NOT be paying the extra £5 and would appreciate if somebody would rectify the situation.
Thanks in anticipation
Mark
Username : mrmarkus1981
28-11-2011 9:30 AM
I can't be sure why this has happened, but will look into that further. I can't really stop the £5 from going through but I will make sure it gets refunded afterwards.
A data transfer cap is in place now so there should be no extra charges.
28-11-2011 9:37 AM
Is my usage to be reset tonight, now my billing date has moved?
Mark
28-11-2011 9:48 AM
Adam.
28-11-2011 10:03 AM
Maximum extra monthly spend: £10.00
28-11-2011 10:09 AM
28-11-2011 10:14 AM
28-11-2011 11:44 AM
28-11-2011 11:50 AM
28-11-2011 12:47 PM
28-11-2011 12:50 PM
So it looks like it is our bad after all, sorry for any confusion.
It's due to be fixed tomorrow so I'll revisit this then for you.
Adam.
01-12-2011 9:54 PM
P.S My pings have also been really bad recently, getting my backside kicked on MW3 - not happy
02-12-2011 9:14 AM
This is an odd one. You're in sync at over 8000 and your profile on our side is at 7000, which is correct. However I can't get any records from the delta report side of things, not sure why, and a consistency check test is also failing to complete.
What's your profile as shown on a BT speed test?
02-12-2011 10:28 AM
Download speedachieved during the test was - 6061 Kbps
Additional Information:
Your DSL Connection Rate :8096 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7000 Kbps
02-12-2011 11:26 AM
