Estimated line speed - how about getting it correct
Oldjim
Resting Legend
Fixes: 63
Estimated line speed:
    1.5Mb (Accurate to within +/- 1Mbit) - Checked on 2010-12-17 16:53:01
Current line speed:
    3.5 Mb
Previous sync for over 35 days 4096kbps (not below 4000kbps since early Sept 2010)
Present sync for 28 hours 4736kbps
37 REPLIES 37
adamwalker
Fixes: 223
Re: Estimated line speed - how about getting it correct
Jim,
I'm not aware of any other discrepancies with this so I can only urge customers to make us aware if they see this happen.
 Adam Walker
Fixes: 577
Adam,
See this thread http://community.plus.net/forum/index.php/topic,89742.0.html
adamwalker
Fixes: 223
Thansks MisterW but I would need examples such as what Oldjim has already posted,
 Adam Walker
Fixes: 577
Adam,
Mine are in that thread but for information.
In October last year the Wholesale checker said
Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a fixed line speed up to 1Mbps. However due to the length of your line the 1Mbps service may require an engineer visit who will, where possible, supply the broadband service.
Our test also indicates that your line currently supports an estimated ADSL Max broadband line speed of 3Mbps.
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 3.5Mbps. Our test also indicates that your line could support an estimated ADSL 2+ Annex-M broadband upstream line speed of 500Kbps and downstream line speed of 2.5Mbps.
Your cabinet is planned to have WBC FTTC by 31st December 2010. Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 17.8Mbps and upstream line speed of 7.7Mbps.
In December it said
Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a fixed line speed up to 2Mbps.
Our test also indicates that your line currently supports an estimated ADSL Max broadband line speed of 8Mbps.
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 15Mbps. Our test also indicates that your line could support an estimated ADSL 2+ Annex-M broadband upstream line speed of 1Mbps and downstream line speed of 9Mbps.
Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 28Mbps and upstream line speed of 6.2Mbps.
and now its back to the October figures.
Just for completeness, my line has an attenuation of 28db at 300khz ( as reported by my 2700HGV ) and is in constant synch at 8128k with a SNR of 8-9db.
Edit : and from the PN portal
    3.5Mb (Accurate to within +/- 1Mbit) - Checked on 2009-03-31 15:29:08
Current line speed:
    8 Mb
linux
Quote from: _Adam_Walker_
... so I can only urge customers to make us aware if they see this happen.
Here you go:
    1.0Mb (This may vary between 1Mb and 3.5Mb) - Checked on 2011-01-25 20:56:09
Current line speed:
    5.5 Mb
anniesboy
Heres mine
    2.0Mb (This may vary between 1.24Mb and 3.24Mb) - Checked on 2011-01-05 16:03:33
Current line speed:
    7.15 Mb
pierre_pierre
Phone exchange:
   BRAINTREE
   8Mb (Accurate to within +/- 1Mbit) - Checked on 2009-08-09 03:31:10
Current line speed:
   14 Mb
Sam monitor results below
linux
Is it the conclusion of this thread that the "Estimated line speed" is not accurate?
nozzer
Certainly looks that way!
7Mb (Accurate to within +/- 1Mbit) - Checked on 2010-07-09 11:31:49
Current line speed:
10 Mb
linux
Well, that being the case, may I suggest that Plusnet remove the Estimated line speed from the High-speed Broadband link under Connection settings. It will only confuse people.
Wheel_nut
Here's mine. Note that my Sync Speed is 6560 kbs:
    2.0Mb (This may vary between 1Mb and 3.5Mb) - Checked on 2011-01-10 11:08:53
Current line speed:
    5 Mb
Surely you now have enough evidence Adam  Roll_eyes
pierre_pierre
Phone exchange:
    BRAINTREE
Current line speed:
    15 Mb
Fixes: 577
Yours is probably the only one there that's ALMOST right Pierre. Since the estimate is quite old, I suspect its for ADSL1 and you're now on ADSL2+.
pierre_pierre
I changed to ADSL2 8 Aug 2010
