Estimated line speed - how about getting it correct
- Feedback
- Plusnet Feedback
- Estimated line speed - how about getting it correc...
Re: Estimated line speed - how about getting it correct
16-02-2011 9:39 AM
Phone exchange:
UCKFIELD
Estimated line speed:
8Mb (Accurate to within +/- 1Mbit) - Checked on 2010-07-13 11:53:22
Current line speed:
15 Mb
16-02-2011 9:39 AM
My daughter's used to be slightly pessimistic, but is now way out:
Zen SOGEA 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
16-02-2011 11:05 AM
| Estimated line speed: 7Mb (Accurate to within +/- 1Mbit) - Checked on 2011-01-03 13:09:42 Current line speed: 7.15 Mb |
17-02-2011 11:07 AM
Apart from a couple of faults I've had, I've always connected at 2Mb. With the addition of an ADSLNation faceplate, I can get up to 2.5Mb, but it isn't stable enough to stay up there for more than a couple of days,
0.5Mb (Accurate to within +/- 1Mbit) - Checked on 2011-01-30 13:46:21
Current line speed:
2 Mb
08-03-2011 10:45 AM
Oldjim made me aware of this thread.
8Mb (Accurate to within +/- 1Mbit) - Checked on 2009-11-19 19:33:30
Current line speed:
2.5 Mb
I notice how many people on this thread are getting higher line speeds than their estimated.... I wouldn't mind having that complaint...
09-03-2011 9:28 AM
I've just tested the line and it's consistenly syncing below the fault threshold rate, so provided that's the same with the router in the master (or ideally test) socket with all other items removed from the line then we can get that raised for you. If you post back letting us know the downstream sync rate of the router when it's plugged in like that we'll advise further, it'd also be a great help if you could run a couple of speed tests on the BT tester at http://www.speedtester.bt.com
Hope that helps,
09-03-2011 11:56 AM
Quote Estimated line speed:6Mb (This may vary between 6.5Mb and 15Mb) - Checked on 2011-02-10 18:11:40
Current line speed: 8 Mb
This is my current sync:
Quote Uptime:3 days, 0:31:07
DSL Type:G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]:23,533 / 11,540
Bandwidth (Up/Down) [kbps/kbps]:448 / 10,518
09-03-2011 5:10 PM
When you signed up for your broadband account, we performed a check on your telephone line to give you an estimated speed your line might achieve.
Now that your service has now been active for 14 days, we thought we'd let you know the speed as it stands today, by way of comparison.
Estimated line speed: 5.5Mbps
Current line speed: 2.5Mbps
10-03-2011 9:30 PM
Quote from: Matt Hi Gorvul,
Hope that helps,
Hi Matt,
I noticed just now that the estimated line speed I quoted earlier (8Mb) was dated 2009. That would have been estimated from my previous address, where my line speed was hugely faster than it is here. I am at a different address now, (I took the same phone number with me), so anyway, what I'm saying is, is that the estimated line speed is out of date, and irrelevent I imagine.
For some reason, perhaps out of date BT phone lines in my area (not actually that far from my old address), my line speed is a lot worse here, even though I'm physically nearer to the exchange.
Anyway, I'm not sure it's exactly the information you're asking for, but I'll post this here:
Link Information
Uptime: 13 days, 18:44:58
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 443 / 3,399
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 1.00
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 31.5 / 51.5
SN Margin (Up/Down) [dB]: 17.0 / 15.0
Loss of Framing (Local/Remote): 167 / 0
Loss of Signal (Local/Remote): 15 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 183 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 8,243
HEC Errors (Up/Down): 0 / 6,477
that info was taken from my router - thomson one, PN supplied.
it's been plugged directly into the test socket with plate off since about last May or April 2010. No other equipment apart from a phone.
I'll do a btspeedtester test now, but like I posted somewhere else, I don't want my pings messed up from testing stuff at your end. My pings are very good, and I want them to stay that way.
I've just done a btspeedtest.... here are the results:
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
2226 Kbps
0 Kbps 4000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 2226 Kbps
For your connection, the acceptable range of speedsis 1200-4000 Kbps.
Additional Information:
Your DSL Connection Rate :3399 Kbps(DOWN-STREAM), 443 Kbps(UP-STREAM)
IP Profile for your line is - 2500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 12.83:25.27:61.94 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Upload Speed
320 Kbps
0 Kbps 443 Kbps
>Upload speed achieved during the test was - 320 Kbps
Upstream Rate IP profile on your line is - 443 Kbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
does this help?
10-03-2011 11:10 PM
I think from those stats you have interleaving off, is that for a reason? You may get far better speeds with interleaving on and the noise margin reset.
11-03-2011 2:33 PM
who resets my noise margin?
11-03-2011 3:12 PM
Here are the details:
BT LineCheck Results - Live
Telephone Number: removed
Exchange: also removed (I'm sure Gorvul will decide if it's worth providing this information to all forum readers
DSL Availability: Yes
Highest Available Speed: 3.0Mb
Max Enabled: Yes
Max line speed: 3.0Mb
Wbc Enabled: Yes
Wbc line speed: 3.0Mb
AnnexM Enabled: Yes
AnnexM Download Speed: 1.5Mb
AnnexM Upload Speed: 0.5Mb
Looks about right for what you're getting to be honest.
12-03-2011 12:06 AM
I've never really understood why I get such low download speed, when I live a stone's throw fromteh exchange. Perhaps the technology is just old in my area, or maybe BT want me to join their superfast BB when the time comes/if it's not already come.
I've no idea. But, like I said, I'm fairly close physically to the exchange, but maybe BT like to keep the expensive properties in the area supplied with the better service.. I've noticed the council do that with the potholes, mainly being fixed first on the posher roads..
12-03-2011 2:38 AM
12-03-2011 10:04 AM
2.0Mb (This may vary between 1.24Mb and 3.24Mb) - Checked on 2011-01-05 16:03:33
Current line speed:
7.15 Mb
dick:green Image tags added.
- Feedback
- Plusnet Feedback
