Enough is enough.....
pierre_pierre
Re: Enough is enough.....
that is absolute and utter twaddle
Steve
Seasoned Pro
Quote from: MOGO
Now with the new provider and hitting speeds up to 9MB and no new wiring or hardware just a different ISP  Roll_eyes
Can you beat this?
If life gives you lemons, make lemonade.
pierre_pierre
I could if I was bothered, FTTC is enabled but I am on Value and Synched at 17M  on ADSL2+ and samknows results arnt bad either
Steve
Seasoned Pro
Yeah this Plusnet LLU Is awesome!! Cheesy
fourfourdevon
I can beat that
And no, it's not FTTC or anything fancy  Smiley
Strat
Fixes: 565
....and I'm on standard 'up to 8Mb/s' Undecided
fourfourdevon
WTFlip?  How on earth you get that?
Steve
Seasoned Pro
The mods get priority on the network! Grin
pierre_pierre
this what BT think on my line
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 17Mbps; typically the line speed would range between 10Mbps and 19.5Mbps. Our test also indicates that your line could support an estimated ADSL 2+ Annex-M broadband upstream line speed of 1.5Mbps and downstream line speed of 12Mbps; typically the downstream speed would range between 11Mbps and 13Mbps.
Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 34.6Mbps and upstream line speed of 7.2Mbps.
Strat
Fixes: 565
I suspect it's Kaspersky again. I used to get cock-eyed results on www.mybroadbandspeed.co.uk but since updating it to the 2011 version it's ok.
pierre_pierre
you could always use the BBC checker and get even more stupid results  http://news.bbc.co.uk/1/hi/technology/8172065.stm
Strat
Fixes: 565
Well I did install W7 SP1 last night so maybe that's why Roll_eyes
@Pierré
Quote from: http
Your connection to bbc.co.uk is working at 5.5 Mbps.
...hmmmm
fourfourdevon
The BBC bandwidth checker, is I reckon accurate to +/- 30%
pierre_pierre
I have had any thing from 3.5 to 8.5  Mybroadband is normally on 10 plus to this machine via WiFi
glloyd
What do you mean it's twaddle.  BT run there broadaband over the local loop as do BE. The only difference is the equipment used. Instead of BE using BT's equipment they use their own. So we ARE all on local loop Roll_eyes
Quote from: pierre_pierre
