Do Plusnet use this nifty bit of software
- Feedback
- Plusnet Feedback
- Re: Do Plusnet use this nifty bit of software
27-08-2012 7:20 PM
5 REPLIES 5
28-08-2012 9:32 AM
A long time ago, back in the mists of time, PJ actually got the Digicare guys to trial this. They didn't like it
Apparently it's been updated a lot since then though and we are going to have another look at it soon!
Kelly Dorset
Ex-Plusnet Jobsbody
Ex-Plusnet Jobsbody
01-09-2012 10:57 PM
Suggest you phone customers when promised, not play around with a filter system to stop you seeing them first
03-09-2012 9:48 AM
Quote Suggest you phone customers when promised
Is there a specific instance where this didn't happen that we need to know about or just generally commenting?
EDIT:
I can see that you've posted here http://community.plus.net/forum/index.php/topic,107216.msg917153.html#msg917153 about an issue, Chris is looking into this today.
03-09-2012 9:52 AM
If you'd looked at the last posts of this user you'd have rapidly realised what he was on about!
You've ONE day for the home move team to return the call promised 24/8/12 before he cancels his direct debit!
Edit: You'd modified your post while I was typing mine!
03-09-2012 10:39 PM
Thanks for your input Jelv, explained so well.The issue is now sorted out thanks to Chris and Marc.
- Feedback
- Plusnet Feedback
