Discount for Recommend a Friend to Plusnet
- Feedback
- Plusnet Feedback
- Discount for Recommend a Friend to Plusnet
05-02-2012 10:17 AM
Hello,
I’m afraid that your recent communication is not accurate and misleading in my view.
The text and graphic imply that for each successful recommendation, the customer `can save` up to £5.50.
But what you actually mean is
The discount that you get each month depends on the product that the person you recommend signs up for.
For Plusnet Value* and Extra broadband you'll get 50p off your bill every month that they are with us.
For Plusnet Value Fibre broadband you'll get 50p off your bill every month that they are with us. If they take Plusnet Extra Fibre broadband you'll get 75p off each month.
You'll also get extra discounts if they take our one of our Home Phone packages.
You can see the discount values for all of our products on this page.
There's no limit to the discount that we'll give you - the more people that join because of your recommendation the more money you'll save. We'll even start paying you if you recommend enough people.
So the advert should be reworded removing the following text “For each successful recommendation”
As it could be read that for each successful recommendation the customer will receive a discount of £5.50 and this is clearly not the case!
4 REPLIES 4
Re: Discount for Recommend a Friend to Plusnet
05-02-2012 10:35 AM
like most things, people dont read
it does say those magic words "Up To" and you can indeed get £5.50 if you get some one to sign up to SDSL 2Mb
see here http://community.plus.net/forum/index.php/topic,102218.0.html
05-02-2012 11:07 AM
It's a valid point though - I hadn't realised you could get so much from one referral, but now you've pointed out how I realise the ad's correct. Unfortunately I've only managed to refer one person and he's not entered my details - although I've discovered he's now connected to PlusNet!
05-02-2012 11:20 AM
If you can get him to raise a ticket saying he was recommended by you and then you raise a ticket giving his username you should be able to get the referral payments.
05-02-2012 12:34 PM
Ref: Pierre_pierre
The advert is correct then. NP - I'm Sorry I missed that, taken from the other thread....
The SDSL 2mb connection costs £99 per month, so £5.5 referral sounds about correct
- Feedback
- Plusnet Feedback
