Commenting on library items
Fixes: 251
Just been reading Chris P's new guides to fault finding and sought to comment on one.
The comment box said "You are logged in as Townman"
First attempt was rejected because "You must be logged on"
A later attempt was successful, but an advice notice stated that "comments from non logged on persons must be inspected before being published" even though the comment was marked as being from "Townman".
I think something is a little broke!
3 REPLIES 3
Chris
Legend
Fixes: 169
Re: Commenting on library items
Yes, the Library has a few issues, in particular with keeping you logged on. It's on the workstack to get fixed, but other things take priority at the moment.
Fixes: 251
Chris,
Thank you for the prompt reply.  I'm sure that there are things of a much higher priority.  Is there a list somewhere of such know issues that users can consult before providing feedback, thereby lessen the distractions to very busy people?  If not, would putting one together be beneficial to avoid reporting (again) what is already known about?
Cheers,
Kevin
spraxyt
Resting Legend
Fixes: 75
I think the second 'comments from non logged on persons …' message is actually a wording error in the WordPress software. It should say 'the first comment from users is subject to inspection …'. Now that you have had a comment approved you should find subsequent comments go straight through.
David
