Broadband
Squib
Broadband
My phone line is noisy and is over 1 thousand metres from cabinet ,why have I been sold fibre broadband?
2 REPLIES 2
Oldjim
Fixes: 63
Re: Broadband
At over a 1000 metres to the cab fibre is still viable http://www.thinkbroadband.com/guide/fibre-broadband.html
The fact that you have a noisy line isn't something which would be known as part of the ordering process and in any case the noise source may not be between you and the cab
Have you reported a voice fault (noisy line) as that is the first step to getting it sorted
Have you checked the forecast speeds here http://www.dslchecker.bt.com/
EDIT
I just saw that you had another thread running so the above is only partly relevant https://community.plus.net/t5/Fibre-Broadband/Broadband-speed/m-p/1392017#U1392017
MattyC
Fixes: 46
Re: Broadband
My colleague has picked up the other thread in question.
