Broadband speed cannot be specified in Mb
owalter
In many places, both on the Plusnet website and elsewhere, I see broadband speeds specified as so many Mb, e.g.
https://www.plus.net/home-broadband/package-guides/
says "Up to 17Mb speeds". This is INCORRECT. The correct way would be:
"Up to 17 Mb/s speeds" or "Up to 17 Mbps speeds".
The reason should be obvious: "M" means "mega", "b" means "bit", so 17 Mb is NOT a speed; it is a quantity of data (seventeen megabits: just over two megabytes) . Mb/s or Mbps are the correct ways to state "megabits per second" which is what is meant. Writing Mb is, to me, a clear declaration of ignorance.
BTW: at least it says Mb. not mb, which would mean millibits - obviously nonsense.
Further: in science and engineering, it is correct to put a space between the number and its unit symbol, for the same reason as putting a space between two words in a message in ordinary language. If you want to ensure that no new line occurs between the number and its unit symbol, use a non-breaking space, not an ordinary space.
9 REPLIES 9
198kHz
Fixes: 41
Re: Broadband speed cannot be specified in Mb
Being an inveterate pedant myself, I see where you're coming from, and I agree in principle.
However, where, as on the Plusnet page you referenced, it's obvious in context what's being referred to, I don't think the '/s' or 'ps' is strictly essential.
We know it's speed being quoted, and we know it's not per minute or per hour.
BT technician (Retired)
owalter
'/s' or 'ps' is strictly essential because Mb is not a speed - end of argument. If Mb is OK, it's also OK to say that the speed limit on motorways is 70 miles, or on a long journey my car's consumption is 60 miles, or my electricity consumption in a year is 2000 kilowatts.
My post is intended for action by the website maintainers of Plusnet.
NedLudd
:sigh:
Geoff,
York.
spraxyt
Resting Legend
Fixes: 75
This terminology is unfortunately the norm. It's a short string that potential customers understand. Unless Ofcom forced all ISPs to change it would not be commercially prudent to be different.
Those that do know the unit should be Mb/s just accept it.
David
sjptd
Depends what you mean by 'strictly'.
'/s' or 'ps' is  essential if the aim is to be technically/pedantically correct, which is sometimes very important.  It is not essential to make the meaning of the page clear to most readers;  I suspect that many will not see the difference at all, and that 99.99% of the rest will immediately know what is intended.
The difference between bits (b) and bytes (B) is of course much more important and confusing.  Most people quote 'raw' broadband speeds in Mbps (because that's the way the industry does it) but think of download speeds in MBps (because they know the file size in MB and not Mb).  I've seen many posters confusing or confused by these.
Anotherone
Champion
Fixes: 21
I'm afraid I agree with owalter, and welcome to the forum by the way.
Quote from: spraxyt
That is true, unfortunately, because a lot of the Help and Support pages appear to be written by technically ignorant people and even when the errors are pointed out, with an explanation, they don't get fixed. So it's no wonder that those with a non-technical background do not learn how to express even the basics correctly.
The IP Profile page for 20CN is still wrong, whoever wrote it clearly doesn't understand 20CN speeds are in multiples of 32kbps Roll_eyes
godsell4
Mbs^-1
3Mb FTTC
MauriceC
Resting Legend
Fixes: 17
If we are not careful this debate will slide into BANDWIDTH and its variable definitions depending on usage.    Wink
I understand and value the pedantry when required, but quite happily lapse into layman's terms.
Anotherone
Champion
Fixes: 21
Groan.
