Broadband USO
- Feedback
- Plusnet Feedback
- Broadband USO
Broadband USO
13-03-2020 2:54 PM
Can anyone tell me how to go about getting a better broadband connection under the new 'Broadband USO' legislation that is coming into force in a few weeks time. I'm currently a Plusnet customer and I get around 6-7Mb connection, no fibre available and no 4G signal.
The Ofcom page (https://www.ofcom.org.uk/phones-telecoms-and-internet/advice-for-consumers/broadband-uso-need-to-kno...) mentions:
"Legislation for the USO was brought in by the Government at the end of March 2018, and customers will be able to request a broadband USO connection directly from the designated universal service providers – BT and KCOM – from March 2020."
Does this mean I need to switch from Plusnet to BT? (reluctantly)
Or, can Plusnet request a USO connection from BT/Openreach on my behalf?
Or, as Plusnet is owned by BT, do I need to request the USO connection from Plusnet directly?
Matt
Re: Broadband USO
13-03-2020 3:29 PM - edited 13-03-2020 3:30 PM
You will have to wait for BT to publish details of how to apply later this month. Only BT will provide USO connections (outside Hull), so Plusnet won't be involved (even though BT own them).
Wherever possible BT are likely to provide 4G, with an exterior antenna if necessary. It only needs to provide 10Mbps down 1Mbps up, so even a weak 4G signal will be enough for that.
The procedure will be that you apply, then BT will check your eligibility (no above USO service available, and none planned to become available in the next 12 months), and they will have 30 days to respond. If they offer you a USO connection and you accept it (and agree to pay any cost above £3400), they will aim to complete 80% of connections within 12 months - so it may not be a quick fix.
Re: Broadband USO
13-03-2020 3:50 PM
This topic has been moved from ADSL Broadband to Plusnet Feedback.
Customer and Forum Moderator. Windows 10 Firefox 84.0.2 (64-bit)
Re: Broadband USO
13-03-2020 4:11 PM - edited 13-03-2020 4:12 PM
@Strat, what has this thread to do with Plusnet Feedback. Surely if ADSL isn't the right forum then "Everything Else" would be the most appropriate?
Re: Broadband USO
13-03-2020 4:18 PM
@corringham the move was requested by Plusnet staff.
Re: Broadband USO
14-03-2020 10:29 AM
Who "assesses" the cost ?
and what proof will be provided to the effect that the costing is "above £3400 " .........before you agree ? ? ?
Re: Broadband USO
14-03-2020 1:02 PM
My understanding is that BT will assess the cost - I don't know what evidence they will have to provide for costs above £3400, but I would expect it to be along the same lines as for FTTPoD (i.e. a detailed breakdown of labour and materials required)
Re: Broadband USO
18-03-2020 2:30 PM
Thanks for getting in touch @mattb2
As BT are the USO provider you'd need to switch to them if they're able to offer you anything under the USO scheme
If you're still in contract at the moment you would be liable for any cancellation fees for exiting your minimum contract early.
